Question about Radio Communications
Does the motorcycle Bluetooth headset 4.0+EDR have an intercom system to talk to each other without a phone call. And if so, how does it work?
Posted by Brad brickner on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Posted on Oct 08, 2007
Anonymous
SOURCE: bluetooth headset
THank you thank you.. you helped me solved my problem 0000 password
Posted on May 29, 2008
Anonymous
  • 5 Answers
SOURCE: Iphone 3G blutooth microphone volume extremely low
go to the volume control for mirophone.
Posted on Jul 15, 2009
Anonymous
SOURCE: LG HBS-200 Headset w/Bluetooth. Phone works. Music does not.
iphone works well with LG HBS 200, I am listening to music in iphone though LG HBS 200 right now..it works like charm
Posted on Oct 05, 2009
Anonymous
  • 4 Answers
SOURCE: I can't listen music through my bluetooth headset with iPhone
My Jabra Halo works to play iPhone's iPod music as well as phone calls. So does Jabra Arrow, I'm told. The bluetooth must have A2DP.
Posted on Jan 10, 2010
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
NOT CONNECT TO MY MOBILE PHONE
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Feb 12, 2009 | Insignia Bluetooth Wireless Headphones...
Radio Communications Logo
117 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
