Question about Proscan Televison & Video
How do I find the code for my Proscan Remote Control for my 32 in Proscan TV?
    Top Expert:
  • Proscan Master
  • 10,766 Answers
Proscan DVD Codes = 2118, 2144, 2205, 2319. Proscan VCR Codes = 3000. ON MOST REMOTES: 1. Turn on the TV. 2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light. 3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
Posted on Nov 05, 2019
5 Suggested Answers
Anonymous
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
Anonymous
  • 68 Answers
SOURCE: i have a hughes hrmc-11
auto code search.
hold down the tv button and mute button until the tv button light stays on. press the channel up button(this will cycle thru codes) test with the power button. process may take a few minutes. when the tv turns of press the tv button to store code
Posted on Jan 06, 2009
Dwayne Bowers
  • 86 Answers
SOURCE: Need DirecTV remote code for Proscan 26LB30QD
Direct TV Remote Codes for various devices.
Posted on Feb 15, 2009
Anonymous
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
Anonymous
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Shaw direct remote code for proscan tv
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Jan 12, 2014 | Proscan PS32500 32" TV
Hi, I just bougth a 32'' model # 32LB30QD proscan tv, but I need the codes to play this tv with a direct tv, remot control,,
ok so buy a remote control if you already have one and lost the book search it up on google,dogpile or the companys website
thanx i hope it worked
Sep 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Sep 09, 2009 | Proscan 32LB30QD 32 in. LCD TV
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
May 16, 2009 | Proscan 32LA30Q Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Feb 17, 2009 | Proscan 32LA30Q Television
Need TV Code
i believe because this is a commercial television. look at the power cord -- three prongs - right?
I had to get a universal remote and program the buttons manually from the original remote to get it to work.
Dec 21, 2008 | Proscan 32LA25Q 32 in. LCD TV
Lcd 32" proscan need code for universal remote
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
47 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
