Question about Panasonic Televison & Video
My Panasonic CT-27SC14 TV has dark screen, settings don't fix this. I had a power surge for 5 seconds and it started doing this. No scrisp picture as before.
Posted by Jake Hunter on
5 Related Answers
Anonymous
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
Anonymous
  • 252 Answers
SOURCE: Panasonic CT-36HL43G five blinking lights
check the horizontal transistor
Posted on Sep 29, 2008
Anonymous
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
Anonymous
SOURCE: how to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Posted on Dec 16, 2009
Anonymous
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
Well, Everything said on this site is true. I recently had a breakdown on the same type of TV and through this site and the comments left, I was able to repair my tv for less than $50. (Extra cost for upgrading my soldering iron that wasn't getting hot enough) It was amazing. The feeling when the tv powered up and stayed on. Credit goes to Howard and Chris Palmer for their comments. It is possible. You just have to commit and do it. Its not as hard as you might think. Thanks guys.
Tim
Posted on Jan 24, 2010
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
Panasonic TV TC-2175C, display turning dark
There are mainly two reasons for this fault. The first one is with its screen voltage settings. If the screen voltage settings have gone down [it can be happen automatically in rare cases], the screen will look dark. The second one is with its video output section itself. Anyway, you have to seek an experienced service technicians' help in this matter, if you are not handy in electronics.
Jul 02, 2012 | Panasonic CT-27G13 TV
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
Distorted screen & picture does not fill screen
check smps power supply, capacitors first and the voltages.
May 03, 2010 | Panasonic CT-27SC14 27" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
Sounds like dried up cap either in vertical circuit or power supply.
Apr 27, 2008 | Panasonic CT-27G34 27" TV
Fixing Tilt
YOU PROBABLY TOUCH THE SCREEN VOLTAGE ADJUSTMENT LOCATED ON THE FLYBACK TRANSFORMER. BECAREFUL ADJUSTING IT LPUS IT IS HIGH VOLTAGE USE A PLASTIC ADJUSTMENT DRIVE.
THANKS DOCTOR VIDEO
Apr 24, 2008 | Panasonic CT-27SX11 27" TV
Panasonic CT-27SC14
The high voltage should be around 29.5 KV and not fuctuate between 20-30 KV that would indicate a high voltage regulation issue then. Are the filaments lighted up in the neck of the CRT? If so then yes you are probably looking at a low voltage issue such as a 12 volt source or a a/v switching IC issue.
Apr 23, 2007 | Panasonic CT-27SC14 27" TV
Televison & Video Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
