Question about Canon Office Equipment & Supplies
I get an error code 5,145,61 FIXYA when I try to scan a document on my Canon pixma MX870
6 months ago it was scanning without a problem. I have not scanned anything since 2-2019 , until now (7-18-19) when the error message came up . Why is that?
  • Patrik Parker Jul 20, 2019
    Hi Anonymous, I want to help you with your question, but I need more information from you.
    Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7///
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: i can't scan
hope this will help u about CANON MX310
http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_alp.php?p_sid=Gk-ofu2j&p_accessibility=0&p_lva=&p_sp=&p_li=
Posted on Apr 29, 2008
Ramel Mayormita
  • 240 Answers
SOURCE: I am trying to scan a document to my macbook, but
try to scan the document from the printer panel ..
hope this help..
Posted on May 15, 2009
Anonymous
SOURCE: Scan error with HP Photosmart C4480
Please try "Scanners and Cameras" which comes with Windows to see if you can scan images successfully from your scanner.
_______________________________
Catherine Sea
Dynamsoft | TWAIN ActiveX/Plug-in
Posted on Jan 07, 2010
paulyrussell
Pauly Kendrick
SOURCE: Lexmark, scanner asks for pin code and won't scan without it.
This drove me mad for about 2 hours (I've just experienced the same problem), but have finally found the solution!
Firstly, it depends on what Lexmark you have (as different printers use different software)...
For my Lexmark which is an S600, I went into the program 'Lexmark home' which was in the lexmark folder on the start menu and in my lexmark software folder, went to 'settings' and then 'Network computer name'. From here you can set the pin.
According to people experiencing this problem with other Lexmarks, you can do this via the equivalent 'productivity suite' program through 'network settings'.
Hope this helps.
Posted on Oct 02, 2010
kerguney
Kazim ERGUNEY
  • 577 Answers
SOURCE: can i scan a document
Hi,sorry but you can not...that's why I threw out mine and bought just scanner..alone.....
Cartridges lock all the functions on Canon...this is a tactic for forcing us to buy cartridge..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Jul 21, 2011
SMTP Scan to email problem on a Ricoh MPC2500
Ricoh scanner uses a email account to send the scan to email. That email account has the wrong password on Ricoh settings, probably someone changed the password and now needs to be updated. I hope it helps.
Apr 29, 2014 | Ricoh Office Equipment & Supplies
When I try to download from a YouTube URL, I get an error message that reads:
I was getting the same error message. Mine was working fine before but it started getting error a couple of months ago. I searched the internet and could not find the answer. I finally went to the ilivid site and scanning through the faq, I noticed I had an earlier version then now. So I uninstalled and installed the new version and now no error message. HTH's you.
Oct 06, 2012 | Make IT Simple ilivid Download Manager
Canon MP 270 spooler problems paper jam problems scanning probs
I have had problems with this printer, too. See my Amazon review here:
http://www.amazon.co.uk/product-reviews/B002LVUKL0/ref=cm_cr_dp_hist_1?ie=UTF8&showViewpoints=0&filterBy=addOneStar
(Mine is the second one down).
The Canon MP270 does seem to have a few problems. It's not one of Canon's finest products, to say the least. It seems to be getting a reputation for problems, problems...
I gave up and bought a HP Deskjet printer instead. I know that's not a fix, but I found it was the best solution!
May 24, 2010 | Canon PIXMA MP240 All-In-One InkJet...
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Will not do final scan
What version of windows are you using? Which software are you using to do the scan, and what version? It sounds like either the version of scanning software is incompatible with the version of windows, The USB connection (Assuming it is connected via USB) is a older USB connect (1.0 or 1.1) and a update to the firmware is causing a fault in the final scan, or finally the scanner has gone defunk... time to get a new one.
Jun 19, 2009 | Visioneer OneTouch 9000 Flatbed Scanner
Canon imagerunner 5020I
Hello loosends,
I can merely make a hypothesis. If you can still print to the device and make copies, then something on your network has changed. Typically it has to do with the smtp server or the dns server. The changes can be brought about by many things. Operating system change (E.G. Vista) , Internet service provider changes, permission changes (your I.T. guru would know about all these , especially the latter) or some other network wide change that I have no way of knowing. Typically if there were an inability to reach an e-mail address or for that matter a shared folder the copier will spit out an error report basically saying that a data transmission failed. However, if permissions to accept scanned documents to e- mail or folders have been changed, which might cause denial of delivery, the copier will know its on a valid network and configured properly and may have no reason to generate an error report as all the criteria it looks for have been satisfied. Meanwhile the scanned document goes out into binary limbo. I guess the question that should be posed is"what if anything possibly changed on your network" about a month ago?
Jul 02, 2008 | Canon imageRUNNER 5020i Copier
Hp scanjet 3500 c series
i read somewhere it was SP3 causing the problem and to uninstall it if you can. I tried and it didn't work so the computer broke down a few weks ago and the idiots installed the wrong OS. they put on xp home instead of xp pro and the scanner is working. just wondering if, when i put xp pro back on will it still work.
Jun 12, 2008 | HP ScanJet 3500C Flatbed Scanner
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
I can't scan anything from my MP 460
had probs with scanning at first
1.put doc in scanner
2.push scan
3.choose color or black
4.press scan again
thats what i did works ok
Nov 15, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canoscan Won't Scan
You have to reinstall drivers of your scanner. Thank you.
Aug 11, 2007 | Canon CanoScan 8400F Flatbed Scanner
32 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
