Question about Tools & Hardware - Others
Trying to find sanding pads for a Hyper Tough sander. Can't find the right hole configuration on line or in stores. Six holes with side holes directly in line w/each other (not offset). Any ideas?
5 Related Answers
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Hitachi SV13YB 5
You can go to Hitachipowertools.com and under products scroll down to find your sander. They also have a dealer locator that will find someone in your area. I looked at both the breakdown and manual for this tool and am concerned because it says pressure sensitive, but the literature states hook and loop, so you would have to specify the hook and loop. Let me know if you have any problems finding someone and I will try and help
Posted on Mar 23, 2009
BrianWren
  • 296 Answers
SOURCE: 2005 HD Ultra Classic - replacing the front brake pads
Often it really takes some effort to get the piston fully retracted, as it must be with new pads.
A really helpful tool is a C-clamp. put the anvil on the outside of the caliper, and put the threaded part into the piston, and see if it looks like it will retract a little further.
Posted on Jun 15, 2010
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: DW411 Can I put a velcro
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Dec 21, 2010
Daniel Morton
  • 747 Answers
SOURCE: 1999 ML-320 need picture of hole on rear brake pad Where brake sensor fits in
get a manual from parts store or see if they have a picture of location via their computer
Posted on Jun 28, 2012
wholemkt159
  • 8 Answers
SOURCE: white smoke coming form exhaust
Wonderful.
Share a website with you ,
( http://www.wholesalemkt.net/ )
Believe you will love it.
We accept any form of payment.
Posted on Oct 15, 2012
What is the usages of a PALM SANDER?
Buying something with serious money and using that to your advantage may not always meet the same fate. What would happen if you got yourself a pricy palm sander but couldn't get the job done after spending a considerable amount of time and efforts? That's the result you, for sure, want to avoid. Learning the method to properly use a palm sander can help you avoid such a consequence.
Here are the steps you have to master to use a palm sander efficiently.
TURNING ON THE PALM SANDER
You have to know first to switch on the power button of the sander to make it run. Otherwise, you won't be able to work with it as a sander of wood.
MANAGING SANDPAPER
You have to manage sandpaper and make it into pieces as the palm sander is small in size, and its pad can accept a quarter of the regular sand paper.
KNOWING THE CAPACITY OF THE SQUARE PAD
The square pad of a palm sander can accept the quarter of regular sandpaper. So, cut it into pieces as needed. After making the quarterly pieces of a regular sandpaper tie tightly with the sanding pad.
CARING ABOUT SAFETY
It may sound much that may harm your ears. So please ware the ear sound protector for the safety of your ear. Also, you can use glass for the safety of your eyes but it's not urgent.
CATCHING THE PALM SANDER
Before using as woodworking tool, you have to catch tightly the handle of the palm sander with a hand and another hand will give pressure on the sander for working well and maintaining the center of the work.
Now, the sander is ready for using. When the sandpaper will be needed to change, you have to change it following these steps:
  • Remove the used sandpaper from the sanding pad
  • Manage a regular sandpaper
  • Cut quarterly or as per it needed.
  • Tie the cut sandpaper tightly with the sanding pad
Collecting the accumulated dust In time of sanding the wood, you have to notice the dust collecting hole. When the dust collecting hole gets full, you have to clean it to sand well.
DETERMINING THE DEPTH
Before using the sander on the wood, you have to fix how deep it will be sanded. If you don't do it, you may not get a successful sanding on the wood or it may damage you wood making much deep than your need.
  • After using the sander, please keep it in a safe place for further usage.
It is common that you want the utmost benefits from your palm sander. But, having the highest quality sander does not ensure that you would get the most of it. You need to understand how the machine typically works. To be more precise, you should learn you can use a palm sander.
The above guide is designed to help you with the steps involved in the proper use of a palm sander. Hopefully, the steps are understandable enough.
Source: Learn The Professional Ways To Use Palm Sander
Apr 07, 2018 | Tools & Hardware - Others
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Festool RO 125 leaves scuff marks when sanding
depends how important it is to vacuum the dust, most generic brand sandpaper discs will have different hole placements for the sander and the vacuum cant suck the dust up. if you are getting swirl marks from the edge of the sander, is the disc too small? a generic brand that is slightly larger may work but try and keep the sander flat or the excess disk can cause a little trouble with the finish.
Apr 27, 2014 | Festool 492271 5 Inch Stickfix Interface...
Parts for a 335 sander (6
Part is no longer produced. I am going to adapt a 6" dewalt pad by drilling new mounting holes. (The Dewalt pad has 4 holes.)
Jul 18, 2012 | Porter Cable Tools & Hardware - Others
The sawdust is not going to the bag. I've completely blown my sander with air and tried to unclog anything without taking the sander apart, but still all sawdust stays on the belt and not going up the...
The dust bags on most sanders are only marginally effective. They work OK on random orbit sanders with the holes in the sanding pad, but are next to useless on belt sanders. You might try attaching a vacuum cleaner hose instead of the bag. On the other hand, if the the belt is clogging up, that's not going to be helped by attaching a vacuum hose. The belt is "loading" up probably because the material you are sanding is damp, or maybe you are sanding paint, which tends to melt then stick to the belt. If you are just trying to keep the belt from clogging (or unclogging it), rather than keeping the dust contained, try running the belt against a wire brush after every couple of minutes. Good luck, Al K
May 03, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
Replacing cord and switch on craftsman belt sander 315.117131. which connections (holes) do the wies go into on the switch? Thanks
the switch may have four holes two on top and two on the bottom. tin the cord leads with solder and push the white in one hole and the black in the other hole. the motor leads go into the top two holes one on either side. the switch makes and breaks both sides of the line.
Oct 25, 2009 | Tools & Hardware - Others
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Tools & Hardware - Others Logo
163 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
