Question about Kenwood Car Audio & Video
Whenever I step on the brakes, my car's stereo system turns off. I've done all I can, and am now looking for help please.
Hello. I have a Kenwood stereo, Rockford Fosgate amp, and a MTX Terminator series subwoofer. Stock speakers, the front 2 don't receive any power, the wires are dead. The back 2 speakers are the only ones that work. I've had the set up for about 6 years now, and only in the past year or so has this problem been happening. Whenever I step on the brakes, seemingly randomly, the stereo will simply turn off and give me a Miswire. Check wire and turn on again. error. It is as far as i know not the action of pressing the brake that is causing it. I have changed the ground bolt, checked the stereo for corrosion, unplugged and plugged in every wire I could find, and checked the fuse. Apart from overheating the Amp Which is what I'm starting to think the problem is. I live in Nevada. it gets HOT here. i don't know what else could be wrong. I've done everything I know with not being a mechanic or electrician. Any help would be appreciated.
Posted by Trey Hawk on
john h
    Top Expert:
  • Kenwood Master
  • 23,424 Answers
Need more information like year make and model of vehicle this aftermarket radio is in --most likely you have tapped into one of the data wires or brake system
Posted on Mar 30, 2020
Dariusz Zalewski
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 862 Answers
What i would do I disconnect all speakers from amplifier and check if there still is a problem. If not then speaker wire touching somewhere break light wires. If disconnecting speakers doesn't make any changes, then disconnect amp and see if head unit still turns off. If yes then you have to check all wiring to head unit to look for the short.
Anesh Vassan
    Scholar:
    New Friend:
  • 71 Answers
Hi Trey, i understand that you not a technician, what i do advise is to first get your head unit bench-tested, have all the output channels and currents checked thouroughly.
If that doesnt sort the problem then try a different head unit as a process of isolation.
If the problem still persists with a new head unit, then the problem is definitely with the points of connection from the head unit, OR you may have a weak battery.
The amplifier will not bring on a miswire fault in the head unit.
Cheers.
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Posted on Aug 15, 2007
Anonymous
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
Anonymous
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
Anonymous
  • 103 Answers
SOURCE: MTX Terminator Amp...Red light comes on when it should be green.
its just a power light to let you know its on
Posted on Jul 25, 2009
logosc75
Larry Spears
  • 625 Answers
SOURCE: I recently purchased the mtx
If none of the lights are coming on for the amp then the amp is not getting power and/or ground. Check the connections. Check the fuses. Or the amp is no good.
Posted on May 06, 2011
Mighty Max Brake Lights, Stereo & Clock all stopped working at the same time. Any suggestions?
you may have a bad ground, or a short in one of the wires. pull out the stereo.
Aug 19, 2012 | Mitsubishi Mighty Max Cars & Trucks
Ho to remove stereo from holden barina 99?
Every stereo has side clips.
Have you done this first step?
After you pull it out and finally disconnect all the rear stereo cords from the audio system.
Dec 14, 2010 | Kenwood KDC-MP4028 CD Player
Car stereo wont stay on, goes off when a/c is turned on
You have some connection problem 100%.The radio it should be good if does turn on.
Jun 06, 2009 | Kenwood KDC-MP435U CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
Mar 08, 2009 | Kenwood Car Audio & Video
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
Kenwood kvt-617 ain't working
Look for a small hole in the face plate. Put the head of a pen in it for a few seconds and re-set the system. This should work...
Nov 04, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood Car music system Tel Mute problem
To my knowledge, some Kenwood head units have a wire specifically for this purpose, to mute the stereo in the event of an incoming mobile call. This would be the brown wire. Normally when not connected to a mobile phone, this wire is shielded/covered. It it was inadvertently exposed and touches any metal part, then it would enable the muting. If the wire is covered and not grounding, then an internal fault exists and most likely the trigger inside where the brown wire leads to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Car Audio & Video
Car Audio & Video Logo
140 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
