Question about Power Computers & Internet
My computer was working just fine now earlier in the day But Now all it does is It turns on for a few seconds and turns it's self back off. It gets to the screen where you see the brand of computer it is shown on the screen .like hp,Dell etc. But then it goes blank and turns it self back off . what is the problem do you think . I know you can't say for sure with put seeing in in hand . But I can't even get it into safe mode to run a diagnostic on it . The hard drive is a solid state 1 terabyte with 4 gigs ram . It's a gaming computer that was given to me But I didn't play online games on it though . It didn't have any malware or viruses that I found before it went down . any help or suggestions would help . I used to think I knew how to work on computers to get them. Going but my friends laptop refuses to turn on now too so I'mma loosing my confidence im 0 for 3 .and don't want to even plug in the power adapter to turn on the 4th one I've worked on now Lol
Posted by Kim Clark on
  • Patrik Parker Jul 19, 2019
    Hi Kim Clark, I want to help you with your question, but I need more information from you.
    Please Call Customer Support Call 1 8O5*465*751O Toll Free 24x7
  • The Spaminator
    The Spaminator Jul 19, 2019
    Hi Kim Clark, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Is it a laptop / notebook ?
    Try running it without the battery in laptop see if it can run on the power adapter
    Could be the power adapter is not powering the laptop and battery is now dead flat
    Could be a hard drive crash / major failure
    I had this happen on a laptop with exactly the same symptoms you described. Had to replace hard drive and lost all the data as hard drive was completely crook and would not even power up to spin platters. I know ssd for your situation so you won't heard platters spinning on your drive.
5 Related Answers
bte0655
SOURCE: Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
Posted on May 08, 2008
pankaj_dic
pankaj rautela
  • 1252 Answers
SOURCE: My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Posted on Nov 06, 2008
Anonymous
  • 404 Answers
SOURCE: Computer Beeping, something loose?
looks like u've done most of the steps.
put everything how it was, change the ram to the next availble slot. remove power, remove bios battery "like a watch battery" wait 10min and put back on and power on see what happens
Posted on Mar 11, 2009
Anonymous
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Posted on Mar 16, 2009
Anonymous
SOURCE: Removal of boot.com virus from external hard drive and USB Stick
Silakan baca di >sini<
Desi Vibes
"boot.com" is a virus which attacks the hard drives & the hard drives could not be opened by double clicking. In hard drives after enabling viewing hidden file u can see some "autorun" file & a file named "boot.com" which cannot be removed just by deleting.
Here’s the REAL way to clean this off your system. You should do these steps after a fresh reboot in safe mode.
1) Navigate to the problem drive(s) via the Explore option.
2) Click on TOOLS -> FOLDER OPTIONS
3) Click the button which says ‘Show hidden files and folders.
4) UNCHECK the following boxes:
Hide extensions for known file types
Hide protected operrating system files
5) Find and delete the autorun.ini file and the resycled folder on the root directory of all affected drives.
6) Check “c:\windows\system32\dllcache” for boot.com file and delete it if present.
7) Check “c:\windows\prefetch” for boot.com file and delete if present.
8) Delete all files from c:\windows\temp
(Some files may not delete, that’s ok, they’re in use by the system and not virus files.)
9) Delete all files from c:\Documents and Settings\[USER PROFILE]\Local Settings\Temp
(Again, a couple files may not delete, don’t worry.)
10) Run Regedit
11) Make sure you are at the very first entry of the registry hive. (My Computer should be hilighted) then click EDIT -> FIND
12) Search for “boot.com”. If it finds an entry, delete it. Keep hitting F3 until you’ve deleted all instances of boot.com in the entire registry.
13) Scroll the left column back up to the top and hilight the My Computer again at the top of the registry hive.
14) Click Edit -> Find again and search for ‘resycled’ and repeat as in step 13, deleting the entries as it finds them.
15) Close registry editor and try opening the infected drives. They should work now.
Worked for me at least.
Posted on Apr 16, 2009
Very Slow....Light Black Screen when opeing
If it has not corrected itself by turning the phone off and taking the battery out for a couple of minutes then turning it back on you should try a factory data reset. In Idle mode, open the application list and select
Settings - Privacy - Factory data reset - Reset phone
-Erase everything.
May 23, 2012 | Samsung S6102 Galaxy Y Duos - Black...
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
PC: Won't Turn On
ur memory is not placed well, try removing ur memory back and place it again..
Oct 07, 2007 | Computers & Internet
Computers & Internet Logo
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
