Question about Kenmore Dryers
Hi! Kenmore dryer type 138-00 66914691 shuts off mid cycle even when on air fluff. External vents cleaned last night. Is it worth pulling the back off and looking for trapped lint inside the unit?
Posted by Mark Nelson on
5 Related Answers
Anonymous
  • 525 Answers
SOURCE: Kenmore series 80 gas dryer not heating
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
James Chandler
  • 686 Answers
SOURCE: Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Posted on Feb 18, 2009
Anonymous
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
Anonymous
  • 91 Answers
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
Posted on May 28, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
I have A front load Electrolux dryer model number EIMED55IRR0, serial number 4D02004606 that is beginning to heat up hotter than normal. Near the end of the cycle it creates a buzzing noise and vibration....
Air flow through the dryer is crucial in all tumble dryers - and blockage with lint , or buildup of lint in the machine creates a fire risk. Clean filters after every use - check the cavity for fluff buildup inside yearly. If a condenser, remove the condenser and flush monthly. Check your vent hose for water buildup, fluff buildup and carefully check any vent grids or flaps in the external wall for blockage with fluff. You should get a good blast of air from the outlet when the dryer is running - if not, sort it or you will get overheating.
Buzzing and vibration may be caused by motor running problems, or by the motor start capacitor becoming inefficient - a slow motor will also reduce air flow and cause overheating and fire risk. Hard to tell if the motor is slowing - best observed with the lid off but beware of live wires - observe from distance only. A new motor capacitor usually restores motor speed, but only if drum bearings are in good order. Check small extra pulley on belt tensioner too if fitted - wear here causes mechanical speed problems.
Nov 14, 2017 | Electrolux Washing Machines
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
The dryer shut off mid-cycle. It smelled overheated.
Hi
Your thermostat is shutting you off on mid-cycle because your overheating the dryer...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me thumbs up.
Sep 18, 2011 | Maytag PYE2300AY Electric Dryer
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
My dryer shuts off mid-cycle. It heats up and the drum turns but it will shut off mid-cycle. Sometimes it will re-start immediately and sometimes it takes about 15 minutes before it will start again. Any...
Hi and welcome to FixYa, I am Kelly.
There are only 2 causes for this....
restricted Air flow or
broken / damaged blower fan wheel
- Start by pulling the lint filter and washing it with vinegar and water then soap and water to remove any dryer sheet particulate that blocks what appears to be clean filters.
- Next clean out every dryer passage you can access.... use a vacuum with crevice tool and a "U" bent wire coat hanger to get all of the lint out of the lint filter area DEEP down inside....
- Then pull off the dryer duct from the rear of the dryer and clean the internal ducting of the dryer.
- After you think you are done cleaning... reverse the vacuum airflow to pressure... if you see lint floating in the air your not done cleaning. Start over...
- Next follow the duct work all the way through to the outside wall and OUTSIDE. Clean the dryer vent on BOTH sides of the vent flapper outside the home.
- Before hooking up / re-connecting the dryer ducting again to the back of the dryer... turn on the dryer. Use the back of your relaxed hand over the duct / vent outlet of the dryer... the air flow must be strong enough to push a relaxed hand / wrist gently away from the hole.. IF you do not have this kind of air flow after your cleaning session... the most probable failure is the hub of the blower wheel / fan is cracked allowing the blower to spin on the motor shaft.
I think once you get things cleaned up... your dryer will return to normal again. My last comment.... and I am being honest. I have made a lot of money... cleaning out dryer duct work after the customer said they had cleaned it very well. I finished the job they started.... and got paid for doing so. I am passing on 40 + years experience here for free because I believe in helping people help themselves..
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Dryers
Hi, i have a homebrand dryer. Model: TD50-89S. Without asking first,my son transferred washing to dryer. Unfortunately, there was alot of white fluff all over washing and he assumed the dryer could take...
Your duct work is probably clogged with the fluff, which will not allow the air to flow though like it should. When that happens, the heat builds up on the cabinet and the heat sensor shuts down the heat. Its an easy fix, it this is the case. Just remove the duct from the dryer, clean it out, clean out the fluff from the dryer duct connection, then go outside and inspect the outside dryer vent for clogs. Make sure the flapper is working on the outside vent as well. Good luck!
Oct 26, 2009 | Whirlpool LER7646E Dryer
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
Kenmore dryer
hi. thanks for the question. lay dryer on the floor, front down. remove back panel .remove air duct on the left, where the lint filter goes. remove and clean all lint. clean all venting .check heater for broken coils. thanks the appliance doc
Oct 05, 2008 | Dryers
Overheating and Won't Start
Does your dryer run at all? If the drum turns, but the dryer does not heat, click on the follwing link for advice:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now, if your dryer does not run at all, you can use this link for more thorough information:
http://www.fixya.com/support/r385301-thorough_dryer_advice
I'm sure you've already made sure the dryer vents are clean, but if your dryer is running extremely hot like you mentioned, it usually means there is insufficient air flow. If you have ensured all the external duct work is clear, you may still have a clog INSIDE the dryer. In addition, if you are in the habit of pushing the dryer all the way up against the wall, you may be crushing the dryer vent hose to the point where it cannot push air. I mention most of this in these write ups. Please take the time to read through the information. If you have any questions, need help in diagnosing the problem, or assistance in locating parts, please let me know. I hope this helps you.
Jul 10, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
177 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
