SOURCE: washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
SOURCE: Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
SOURCE: brown spots on clean white clothes
The drum seal is bad in your dryer. Those brown spots are burn marks. It's actually burning your clothes. Unfortunately this is not an easy fix. The same thing happened to my wife and I. I can fix many things, but I decided this wasn't worth fixing since I'd have to take apart the whole dryer to fix it. It would've been very time consuming and you'd have to have the technical ability to tackle the job. We just bought a new dryer.
SOURCE: starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
SOURCE: Brown and gray spots on white clothes.Clean the
get who did it back,not something you can fix
