Question about Homedics Audio Players & Recorders
Homedics ss-4000 digital clock display runs constantly.
Posted by jdhester97159 on
3 Related Answers
Anonymous
SOURCE: homedics SS- 5000
Hey, OK so you know how when you plug the clock in it takes like 5 minutes to upload? Well wait till you have the time set the atomic thing stops flashing. Now when you get there press the button on the inside of the outside temperature thing. Not the c/f one. The red dot should flash on the front of the thing your holding. It should work after that. If not then make sure you don't have any computers or cell phones by it that messes with it. Hope this helps.
Posted on Jan 22, 2008
Anonymous
SOURCE: Homedics SS-4000 Clock Projection Display Problem
per Ken in response to SS-4500: Worked for me right away! keith Ten8
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Posted on Jan 05, 2009
Anonymous
SOURCE: homedics soundspa clock radio ss-4500
I had the same problem - the directions can now be found here: http://media.homedics.com/IBs/SS-4500_IB.pdf
Posted on Aug 03, 2009
HoMedics SS-4000 adaptor replacement specs.
Google (Homedics)(SS-4000)(manual) without parens for guidance.
Aug 03, 2018 | Homedics Audio Players & Recorders
Removed battery on homedics ss-4510 while it was unplugged, I know the caution sticker says NOT to do this....now unit is compeletly dead, is there any resetting it, or is it just a paperweight now?
Hmmm well yes it indeed indicates that this must not be done, as if it is it will often ruin the unit, as i suspect it has in your case, indeed it is now a paperweight, sorry. The battery removal removes the memory setup contents and once removed it "Forgets" all the settings.
Aug 09, 2011 | Homedics SS-4000 Clock Radio
Need the specs for the Homedics ss-5010 power adaptor
Product Attributes
Product attributeProduct Line: SoundSpa
Product attributeProduct Model: SS-5010
Product Summary
Manufacturer: Homedics
Mfg Part#: SS-5010
Buy.com Sku: 211467114
UPC: 031262038029
UPC 14: 00031262038029
Package Weight: 1.9 lbs
Buy.com Sales Rank: 64081
Advertisement middle
Features
Product Type Desktop Clock Radio
Manufacturer Part Number SS-5010
Manufacturer Website Address www.homedics.com
Manufacturer HoMedics EMEA
Product Model SS-5010
Product Name SoundSpa Premier SS-5010 Clock Radio
Product Line SoundSpa
Brand Name HoMedics
Frequency Band/Bandwidth AM/ FM
Tech Specs
Brand Name HoMedics
Frequency Band/Bandwidth AM/FM
Feb 13, 2011 | Audio Players & Recorders
I need a manual
Link HERE for the Homedics manual download page.
You need to move down on the selection box to 4/5 way down to see SS-4000.
Download will take minutes.
Feb 01, 2011 | Homedics SS-4000 Clock Radio
How do I get the battery to work? Is there a trick? I just put in a brand new battery and it won't run. Plug it into the wall, and it's fine. Help
in the manual it says all the batt does is back up the settings and back up alarm but displays will not work. so there is nothing wrong with your unit.
Jan 13, 2011 | Homedics SS-4000 Clock Radio
HOW DO YOU SET THE HOMEDICS SS-4500
http://www.retrevo.com/s/Homedics-SS-4000-Clock-Radios-review-manual/id/21951bh630/t/1-2/
having the manual will be your best option, just click on the link below
Nov 12, 2009 | Homedics SS-4000 Clock Radio
Ken
Jun 07, 2008 | Homedics SS-4000 Clock Radio
Projection display
Ken
Jan 11, 2007 | Homedics SS-4000 Clock Radio
43 people viewed this question
Top Homedics Audio Players & Recorders Experts
Ekse
Vincent G
Vincent G
ray gallant
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
