Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
I have a Toshiba 46H83. Everything seems to be in working order, but I have no sound and the mute is not on....Can you help?
Posted by lndlakes on
  • lndlakes Sep 05, 2009
    I did check that but still have no volume.
Anonymous
  • 63 Answers
Check in the menu under audio and set up to make sure the speakers are not turned off.
Posted on Sep 03, 2009
Apple tv has no sound on my toshiba 46h83 tv
How are you connected and in what way? You should be able to rule the set in or out:
First: does the set have sound with only a DVD player connected to a rear input?
Second: are the speakers turned to OFF in the main menu?
give as much information as you can so I may be able to help.
1helpful
TOSHIBA TV NO PICTURE
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Picture is Dark on all stations
It sounds like a bulb. I would call toshiba and ask them what the replacement part is for that. I briefly googled for it but couldn't find the matching bulb for the 46H83
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
