Computers & Internet Logo
Posted on Sep 03, 2009
No sound from speakers with windows vista
I have no sound from my speakers when playing CDs or Youtube etc, but they work OK with Skype.
Advent EcoPC with Windows Vista
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
52
Points
Check to see if the cable has been connected from the CD drive to the Sound card or the mother board. You may also want to reload your CD drive software or make sure that the drivers are properly loaded.
My sound is not working when I play music and stuff, but when I run test, the sound works. The mixer shows that sound is playing but none comes out.
On a high end sound card there are DEVICE,WINDOW SOUND,CD,WAV and MP3 individual settings.
Right Click on the speaker icon (next to clock) and open mixer to max out individual levels.
Application like Youtube and Skype has there own settings.
Did you connect the CD to sound card cable?
Double check to make sure this cable is connected.
More sample pictures link HERE
If your motherboard has built-in sound card then connect the cd to the motherboard CD_IN connector.
2helpful
2answers
Laptop speakers not working!!!
If you are using Windows Vista.
Step 1: Click on Start then type Sound and select sound from the list.
Step 2: Under Playback Tab please select Speakers and Dual Headphones and click on Set Default.
Step 3: Then click on Apply then sound from your notebook should work.
If these steps do not work then the best option is to re-install the sound driver'.
--Steven Vas (The one)
5helpful
Vista Black Edition 2009, Audio driver not wrkng. Suggest best 1?
May be one of missing file, can i get the device ID of the sound card??
Polk speakers play very low sound on youtube etc. windows xp
maybe the problem is on the files you play but not your device.
1helpful
Audio no longer working
You should first try to reinstall the audio driver for your unit, it's available from Acer at this link.
Post your results here so we may further assist you.
No sound through speakers skype only
in windows and messenger there is sound but not in skype
Nov 26, 2008 • Skype IM
1helpful
2answers
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
3answers
Windows Vista problem
You need to download the driver, go to the web site and find the download
http://www.norcent.net/main/support_product.asp
Grand Canyon Tech
Grand Canyon Tech
