Hello Patty,
To run a factory reset, locate the reset button on the connector panel. It's a small, recessed button that requires a pen to hold down. Hold it for 15 to 30 seconds to reset the television.
Alternatively, reset from your remote by locating the "Settings," "Advanced Settings" and "Factory Reset" option.
Click on this link below to see your TV manual.
Good luck,
JP
https://www.manualslib.com/manual/1215207/Emerson-Ltdn42v68us.html#manual
Posted on Jul 19, 2019
SOURCE: I have an Emerson 42"
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Hoping this will work to solve the problem..
Posted on Jul 07, 2011
SOURCE: Emerson LTDN42V68US HDTV dead screen
Check its main power supply regulator board for the fault. Replace it as card basis.
Posted on Oct 27, 2012
SOURCE: My tv is the Emerson Modell LTDN42V68US and it has a flickering picture and then no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 20, 2016
