Washing Machines Logo
MAYTAG PERFORMA MANUAL
I NEED THE OWNER'S MANUAL FOR THE MAYTAG PERFORMA WASHER, PLEASE
Posted by juankar62 on
Anonymous
  • 41 Answers
Try www.lpdlpd.co.uk
They deal with most maytags and are a very helpfull company.
John
Posted on Sep 03, 2009
Can I reverse the door swing on my Maytag Performa dryer>
http://www.maytag.com/-[PYE2300AYW]-1109316/PYE2300AYW/
Here is the link to the owners manual. This feature is not mentioned. Look at the molding in the metal case of the front of the dryer. See if there are identical moldings for the door and latch on both sides. If not, no. Only alternative is to get longer connection hoses and swap washer with dryer left to right.
Need to know cu ft capacity of maytag performa dryer model pyet344ayw
Go to support on the Maytag website. Enter your model number, click on downloads, and select an owners manual.
murf427
3helpful
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
1helpful
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
1helpful
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
3helpful
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
1helpful
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
I'm looking for an owners manual, else
yes - that is the way.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
Top Washing Machines Experts
Marvin
Marvin
W.L.
