I have had similar problem with my HP C6180. Over several months I have replaced Lt. Magenta at least 6 times. Finally I got a "Cannot Print" message after the 6th full cartridge. I tried removing/replacing cartridges, doing a hard reset, and clearing the hardware failure status (press # and *, enter code 1,2,3, scroll to 'System Configuration' press OK then scroll to 'Hardware Confifuration) - all to no avail.
I decided to remove the BIOS battery. Only do this if you're ready trash your C6180 and able to buy a new printer immediately! Remove 2 the black screws holding the left side panel in place and remove it to reveal the circuit board. Remove 5 silver screws securing the circuit board, and carefully tilt it up. On the back side, center front, is a silver 3 Volt Lithium battery; remove it. Cover the printer and let stand overnight. I did this, and when I put the battery back in and powered up the printer, error messages were gone, and it printed normally. I was lucky, but if you're prepared to take a total loss on your C6180, this might just work. My theory is that the hardware "forgot" it' error message.
Hi there !!
The printer powers up properly, but
when a print job is sent, the power light flashes and an error message
appears. The error message could be any of the following:
Try
removing and reinstalling the ink cartridges. If this does not correct
the problem, the resume light will flash and the carriage will remain
in the middle of the carriage guide when the top cover is closed.
Follow the instructions below to resolve the problem.
Instructions
Hope this will help.
NOTE:
The ink cartridges should not be removed from the printer for more than 30 minutes.
Regard's
Anurag Shukla
Without knowing i tore the copper thing in my cartridge.will my printer work now?
Unplug, remove ink, using a new pencil eraser clean contacts on printer.
