Question about Epson Office Equipment & Supplies
Fatal error 1A39 on Epson sure color S70670 - Epson Office Equipment & Supplies
Posted by Kurt Meister on
  • Patrik Parker Jul 19, 2019
    Hi Kurt Meister, I want to help you with your question, but I need more information from you.
    Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
3 Related Answers
tomsud
SOURCE: EPSON 11800 Having an Error code: 1A39
hi the same for me 1A39 on a 9900, i check everything nothing else to do than to change the print head, in fact it's an active signal send by the head it self.... mean that it's defect ..........good luck ! good forum for help on epson printers : http://www.luminous-landscape.com/forum/index.php
Posted on Jul 14, 2012
jacklee366
Lee Reynolds
  • 541 Answers
SOURCE: Epson Stylus Pro 4900 is giving Fatal Error ID 1A39
have a look here for your error id code http://www.largeformatsupport.co.uk/4900.html
this may help you
Posted on Feb 28, 2013
electricks
ELECTRICKSUSA
  • 279 Answers
SOURCE: have Epson Pro 7890 printer when it runs message appears ( 1A39 ) So to solve this message?
Take all paper out uninstall software and reistall
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Posted on Apr 13, 2014
Error ID : 1A39 . what?
Let us know using the Comment menu what type of equipment it is.
This is an earlier FIXYA question with a similar error message and proposed solutions.
http://www.fixya.com/support/t24982367-fatal_error_1a39
Fatal error 1a39 Epson SureColor Series T3000 Inkjet Large Format Printer...
May 14, 2018 | Office Equipment & Supplies
Epson 11880 error code 1135
By doing a Bing search, it shows that error code means to replace print head. If you purchased it new, it shouldn't need a cleaning. You could try removing the print cartridge(s), then put them back in, making sure they are seated correctly, then restart the printer.
May 22, 2017 | Epson Office Equipment & Supplies
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
Cause:
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
Remedy:
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=220056&prodoid=63096219
Aug 20, 2014 | Epson SureColor T-Series T3000 Inkjet...
Have Epson Pro 7890 printer when it runs message appears ( 1A39 ) So to solve this message?
Apr 13, 2014 | Office Equipment & Supplies
Epson 7900 - 1A39 - Head error
1A39 is a print head failure. The head needs to be replaced although it is very expensive and you are better off buying a new printer.
Feb 06, 2014 | Epson Stylus Office Equipment & Supplies
Jun 15, 2012 | Epson Stylus Pro 11880 InkJet Plotter...
My epson tx 111 showing fatal error and both 2 red lights are blinking contuniously
my epson Tx 111 color printer both red light is blinking and its not working plz give me solution
Nov 20, 2010 | Epson Office Equipment & Supplies
Epson cx 2900
If the error is fatal then there is NOTHING you can do at home to sort the problem out. If Epson are refusing to repair the unit because you have repeatedly used non genuine ink then you can try and take them to task on the legality of that decision (depending upon consumer law in your area) but the chances of you getting it sorted without costing a fortune are slim to none.
There is an error which shows up in the status monitor as MAINTENANCE error and this can fixed relatively easily. It's symptoms are similar. However, a fatal error is generally just that - Fatal - and there is nothing the home user can do as this generally requires parts fitting.
Your non genuine ink is almost certainly NOT to blame for the fatal error though. At worst the **** ink you use will clog nozzles and may even ruin the print head by clogging all the nozzles and causing only blank pages to be produced. BUT can you prove this to Epson in court?
My advice - bin the printer and replace it with one from a manufacturer who appears to give a damn about their products and customers as much as their fat pockets!!
May 26, 2008 | Epson Office Equipment & Supplies
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
