Computers & Internet Logo
Posted on Sep 03, 2009
How can I delete multiple students simultaneously
Anonymous
Level 1:
  • Contributor 43 Answers
  • Posted on Sep 04, 2009
Anonymous
Contributor
Level 1:
Answers
43
Questions
0
Helped
16317
Points
72
First of all where are the accounts othe students located. On Active Directory? If yes log on to the server and go to Active Directory Users and Computers, then go to the Organizational Unit where the user accounts are of the one to be deleted. You can click on one user account ,then to delete multiple users just hold down control button and continue to click the user accounts you want deleted. the right click on the blue part and delete. NOTE: Always make a backup of the users/students you want deleted. you could need their data later again
My vivofit won't sync when I press the button
Hello
Ensure multiple applications are not running simultaneously on the device you are syncing with.
Remove my Vivofit from the devices and re-pair it.
If issues persists, simply delete and reinstall the Garmin Express application and it should solve the syncing issues with your Vivofit.
1helpful
How do you delete a number of emails with a Gmail account?
To delete multiple emails simultaneously in your Gmail account, you can follow the steps below:
1. Login to you Gmail account and go to the location where the emails are stored.
2. Click the checkbox besides the emails you want to delete.
3. After you have clicked the checkboxes besides all the emails that need to be deleted, click "Delete" on the top.
GuruAid.com
I want to delete all the facebook conversation
The fact that you can not delete all conversations with all your friends at once purposefully designed and structured company Facebook
Facebook does not allow to delete multiple simultaneous conversations, but selective deletion (one by one)
If 5 out of 18 students work in college, how many would work if there were 1120 students?
Probably the same 5 students while the rest were studying and going to parties. :)
Set up the solution by paying particular attention to the word 'of'. This is a clue that you will have to set up some sort of division or ration problem.
5/18 = x/1120
From cross multiplication we get x = 1120 * 5 / 18 = 311.111111111
Therefore, approximately 311 students would work if there were 1120 students.
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
2helpful
How can I delete multiple messages simultaneously from email account on Nokia Surge
hi,
This will solve the problem
Go to inbox->options->Mark/Unmark(Scroll down select the items you want to delete by marking it)->Delete
thank you for using fixya have a nice day:-)
What is the basic difference between multitasking multiprogrammin
I would have expected that you would be asking the difference between
multithreading and parallel processing, which is simply a matter of using
sequential processor [multithreading] to simulate simultaneous data streams from multiple processors [parallel processing] while the terms you did inquire concerning are various terms of varying complexity which refer to the simultaneous accomplishment of various tasks.
A multithreading processor alternates the application of tasks to alternating clock cycles of the same processor.
A parallel processor has a matrix of multiple processors assigned to diverse tasks with streaming data from each clock cycle of the same processor for the same task.
multitasking simply means the simultaneous accomplishment of multiple tasks by any means including cyber or human.
Multiprogramming is the simultaneous operation of various alogorithms
where none are halted to allow the others to proceed, which process can be accomplished through with either parallel processors or a multithreaded processor.
Prior to the existence of multiple processors in a single CPU (ex. Core Duo) or even Multithreaded Processors [Pentium Four, PPC], certain types of looping algorithmic methods could be applied [and this programmer did apply such] to multiple tasks to create
the appearance that the tasks were accomplished simultaneously.
The latter was more of a Trompe l'Oeil
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Multiple sessions of Word 2003
You can open multiple documents in Word 2003, and use the "Windows" item on the toolbar to switch between them.
Having multiple copies of Word running simultaneously uses a tremendous amount of memory. One copy of the program with multiple docs opened is a much more efficient way of using the computer's resources.
Would you rather have 4 cars with one person in each, or 1 car with 4 people?
Top Thomson Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
