Computers & Internet Logo
Posted on Sep 03, 2009
Can anyone tell me, which programe I can downloade to open a Lotus database, the data are saved on a disk with an older version than Lotus Approach 97 ( which I have ) but refuses to open the file. Thanks in advance
  • Wayne Holden May 11, 2010
    Type this into your search box: free lotus database converter Follow a few of the links and see if they will help.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2739
Points
27
Go to link:
http://www.experts-exchange.com/Software/Office_Productivity/Office_Suites/Lotus_SmartSuite/Lotus_Notes/Q_21739402.html
1helpful
4answers
A database error occurred
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
1helpful
10answers
A disk utility to recover nsf-file
put it on the new computer and from the Notes File menu switch to that ID when you need to open the old mail file. You can also use the ID to unencrypt the database so that you can read it using any ID file. (Under File-Database Properties-Encryption Settings) I had read about it here: https://recoverytoolbox.com/lotusnotes.html
I transferred Approach to a new computer and imported the old files into it. All 3 databases transferred properly, but today, 2 of the 3 database returned this error message: "This Approach file may...
hi Igot3,
Question The following error occurs when opening a specific Lotus Approach file (.apr):
    "Record Header Size 0x8006 bytes too small."
Cause This issue can indicate a damaged Approach file.
Answer If the error occurs when a file is accessed on a network, try bringing the file down to your local hard drive and opening it from there. If the error does not occur, you may have a damaged network card.
If the issue occurs when the file is opened locally, the file is probably damaged. In some cases, launching the database separately and importing the Approach file may resolve the issue and retain most of the Approach file design elements. In other cases, the file size for the .apr file is indicated as zero (0) bytes. In this case, there is no real data in the file and the file cannot be retrieved. The only workaround is to restore a backup copy.
Best Practices Tip: It is a good idea to create a backup copy of an Approach file before making any significant design changes. Open the file and from the File menu, choose Save As --> type a different file name. You will be prompted to also rename any associated databases which you can choose to do or not. As long as the .apr is the only file that is corrupt, the backup copy can always be associated with the current .dbf datab
http://www-01.ibm.com/support/docview.wss?uid=swg21160817
mastergani
Grand Canyon Tech
Grand Canyon Tech
