Question about Epson Stylus Pro 9800 InkJet Printer
Whene i start my 9880 it giveme a 00010005 error call service waht can i do to solve this problem? thank you.
Posted by inversionesa on
  • inversionesa Sep 03, 2009
    no, nothing is blocking the carraige i don´t see anything that can giveme that error yesterday i put off and totay on morning i turn on and saw the error
Fabio
  • 400 Answers
Make sure there is nothing blocking the carraige (where the cartridges sit).
If there is nothing blocking it then the printer will have to go to an Epson service centre to be repaired as a part needs replacing.
Posted on Sep 03, 2009
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
Giving me a Sevice Error 00010005
  • This error means there is a problem with your printers carriage operations
  • Check the carriage and the cartridges.
  • Remove anything that could be in the way of the carriages.
  • Check the cutter cap which if may also be a cause.
Thank you!
Sep 28, 2011 | Office Equipment & Supplies
Error message: Service Call Error 00010005
This code is usually appearing when the carriage for the print cartrige is restricted by any foreing object or by displacement one of the print cartrige that is rubbing on top of the cover,
Open the cover and make sure the carriage is free of anything try to move it manually to see what can cause this blocage Hope this answer your question Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Office Equipment & Supplies
Vodafone 3g sitteing giveme
To get the Vodafone 3G setting please call your service provider.
They will send you the 3g setting.After you receive please save the settings to your
phone and make it as default setting.You can start using this service.
Good Luck.
Thanks for using FixYa.
Feb 11, 2011 | Cell Phones
I have an crc error problem when i install any game likh fifacricket they give me a crc error plzz givem e solution to solve this problem
CRC error usually indicates a problem with the hard drive. I suggest you do a full scan of your hard drive and have it mark all the bad clusters.
thanks adi
Jun 22, 2010 | Computers & Internet
Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
9880 not print nozzle ink discharge check in self test
Go to Menu and off Auto Nozzle check ...............
I hope it may solved your porblem
Oct 26, 2009 | Epson 9880 stylus pro Printer
Service Call Error - 00010005
This error 00010005 popped up when I was messing with my Print head for cleaing purposes.when I put the print head back into place the lever mechanism that is attached to the cutter blade detached from itself not allowing the printer to move the print head freely.below is a picture I scanned in from my Quick Reference Guide that shows how the mechanism should be. When I saw this I then realised what had happend and was able to put down the cutter blade to re attach the lever mechanism. After this I did not recieve the service code again and the print head was able to move freely. I hope this helps.
Oct 20, 2009 | Epson Stylus Pro 9800 InkJet Printer
Service Printhead Error
this problem come whene printer fuser chamber have faulty ,
fist of all do service of fuser and check
after than change pressure roler and teflone slive if problem not solve
Apr 22, 2009 | Lexmark E450dn Laser Printer
Epson Stylus Pro 9800 InkJet Printer Logo
1,814 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
