Canon PIXMA MP150 All-In-One InkJet Printer Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mp145 i have a E4 error on my mp 145 what should i do? i already change my cartridge into a new one.
Anonymous
Level 2:
President:
  • Expert 987 Answers
  • Posted on Sep 03, 2009
Anonymous
Expert
Level 2:
President:
Answers
987
Questions
14
Helped
284690
Points
132
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY.
Below are the manual way to correct this problem :
1. Turn On Your Printer. 2. Wait Till The Printer Led Screen Show The Error Code ( E4). 3. Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Hope that your problem is solved.Dont forget to give a positive feedback after pressing the accept button.
  • feardiakmal Jul 02, 2011
    i already do what you told.... but still i have this E7!!! what to do now??
  • Anonymous Apr 29, 2012
    I also tried this... it didn't work.. but i try adding some step to this solution.. it work.. the step is; I press & HOLD the black & colour button WHILE HOLDING reset button.. Try it...
1helpful
What mean error code pixma printer mp 145 ( E 8) ?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code Message for Printer Canon MP145 and Canon MP160:
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
4helpful
4answers
I wish a install driver of canon mp 145
Get the latest driver for your printer at www.canon.com/suport ... make sure it is for your operating system ...
1helpful
2answers
I have a problem on my canon mp145 with an error code E4. But I already change it to a new cartridge but still the error code still appears. I also reinstall the drivers but still the same.
Hi, I found this answer on the net. Let me know if this helps
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY. Below are the manual way to correct this problem : Turn On Your Printer. Wait Till The Printer Led Screen Show The Error Code ( E4). Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Thanks
Ranjit
Mp 145
Hi this works with some canon priters try ir
codes for reset:
1. Press and hold the POWER button
2. Turn off the printer by disconnecting the printer power cable,
3. turn on the printer, still holding the POWER button
The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
7. Reconnect the printer cable.
8. And it should be reset.
All best: Pineworks
12helpful
2answers
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
4helpful
2answers
Error e5 in mp 145
change a new black cartridge. the problem wont come back again.
5helpful
2answers
Canon MP 145 ink reset
If i am not mistaken error E4 is printer has NO INK. Check the cartridges first.
62helpful
11answers
Mp 145
How to reset the e27 for canon mp145 printer?
Mp 145
what u mean have u refilled the cartridge a reason if not detect the cartridge is that u maybe have touched the contacts on the cartridge try to wipe of very care fully and insert them again
old marine
old marine
ZJ Limited
ZJ Limited
