HP 1210 All-in-one printer everything works ok except for a thick black line which prints while i try to photocopy the photocopy does print but with this thick black line.
You can always perform the print nozzle cleaning procedure through your printer's software. If it is new, then the black cartridge has malfunctioned. Take it and your receipt to exchange it for another. I'll bet this is the problem since your color is working OK and your text is grayscale (partially working).
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
The image acuisition logic on the scanner assembly is gone bad.
It needs to be serviced / replaced.
Suggestion is to swith to Other psc or photosmart All-In-One Printer
wel i think what you should do is try to disconnect the usb cable and make sure everything is well connected then try to insert the disk wich is the deskjet or try the left cartridge must not be correct so take it out and theninsert it againbut make sure you push the catridge in really firmlyuntil you hear a snap and make surem the hp logois facing towards you
Ok Thanks for your advice.
