I've just purchased a Laser MF001 - MP3 player and have downloaded my songs. Now it won't work, how do I turn in on?
Posted by emilytarra on
Megasom
  • 699 Answers
- Make sure you have installed AAA battery: MP3 player won't work otherwise (it does not need a battery to work as USB memory stick to transfer/delete songs or data) - To turn-on (or off for that matter), press first button on your LHS (eg. same side as earphone plug) for 2 or 3 seconds until (blue) LED is on: if you press button too long after the LED is on, it will switch the player off! - When the LED is on, stop pressing this button: it is ready to play the MP3 track by pressing on this same button until the LED starts flashing (LED will keep on flashing while track is playing). - If you want to skip this track and get to the next track, quickly press and release the next (e.g. middle) button. - The third button (e.g. nearest to the USB plug), quickly press and release, is used to rewind or go back to previous track. - Volume control is also performed by pressing and holding down the second or third buttons Have fun!
Posted on Oct 26, 2009
1helpful
My Sony Walkman NW-A806 mp3 player can't play songs and videos
format the player. and download a new songs and videos... you just reformat it. i have a questions, is the player will turn on? or won't.. if will, just reformat it...
Asking for STMP3500
OK, I can only help with download link to download the software but you will do the installation. This is it: http://www.brothersoft.com/stmp3500-driver-download-300267.html
Also, its a zip file but you'll unzip it then install. Hope that puts a smile on your face.
My MP3 MF001 worked a few times. then it was restricted to the first 5 music numbers . then it would not play anything. it turns on and off but will not play or respond to the next/last softer/louder...
Most digital mp3 players can be reset to factory settings. Also, By going into start computer right click the hard drive its connected to and quick format. All songs will be deleted and you'll be ready to begin anew.
How to download songs to the MP3 player
wel you can use the windows media center to do all the work not media player.
You can do it manually .Go to my computer and check your mp3 player is detected,Now open it and you can paste the songs that you want..
iTunes is not compatible with an ILo player - sorry
The iLo only recognizes mp3, wma, not AAC
3helpful
3answers
You should be able to drag and drop them into the player.
2answers
Sakar or iConcepts mp3 not working????
Walmart and many other sites sells songs that are DRM encrypted, meaning they are copy protected. Your MP3 player will not play these unless it is DRM 9 / 10 compatable. The purchase license permits you to download and play in the first device, when copied to another device the DRM prohibits playback in the second device.
Marvin
Marvin
