Televison & Video Logo
Posted on Apr 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi TV Channel Tuning/Remote Problems
Hi I have a fairly old mitsubishi tv which isn't tuned into all tv channels. The remote will work to change the channels but not to turn the volume up and when I press the menu button to tune in other channels nothing is displayed on the screen. I also got a Universal Remote which works but I still can't tune in channels and it turn the volume up but nothing is displayed on the screen to tell me what level the volume is at. Do you think the problem is with my tv or would I need to find a new mitsubishi remote from somewhere that will suit my tv? Please help!!! :)
richie46
Level 3:
Top Expert:
  • Televison & ... Master 12,962 Answers
  • Posted on Apr 27, 2017
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941709
Points
58151
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
5 Related Answers
Anonymous
  • Posted on Apr 05, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
A
Anonymous
  • Posted on Oct 27, 2008
SOURCE: tuning,auto search mode lock
I need a copy of the codes for the rca remote
A
Anonymous
  • Posted on Oct 29, 2008
SOURCE: Tuning a Channel
To Tune in Philips Machline TVs
Without using remote. Open panel on front of tv
1-- Press the menu key. --screen will now display 5 menu options--
2--press the down arrow key untill Install is highlighted
3--press the vol + key -- now install options appear (language--autotune---mantune--channel no--store)
4--press the down key to select the function required (Autotune is best) Manual is ok if the tv station's freq are known and they can be then given a ch no
5--press the + key to start the function selected ---tv will auto tune in tv stations when completed
6--press down arrow and highlite store then press ok
7--Press menu to clear menu off screen
Anonymous
  • 304 Answers
  • Posted on Nov 23, 2008
SOURCE: tuning a philips remote to a philips tv
instructions on tuning a philips universal remote sbc ru 440 to a philips tv
Anonymous
  • Posted on Jan 17, 2009
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
How do I tune my teac led/lcd digital tv model no:le32a321 without a remote
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
  1. Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
  2. Use the arrow buttons to navigate to the channel setup or tuning menu
  3. Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
  4. If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
  5. Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
2answers
I do I fix white dots on screen
Hi
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
1helpful
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Retuning my remote to TV
Have no idea how I did it but I solved the problem - all I need to do now is work out how to set the AV channel so that I can play the DVD through the TV - all in good time!!!!
2answers
Mitsubishi TV model CY2525
as tv is old please replace it by new kit or whole pcb. now a days you get new pcb(CHINA MADE) at cheap rate with remote & mo of channals more.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
