I have a Frigidaire Gallery Stackable Washer/Dryer, Heavy Duty. The dryer is screeching so bad and leaving little black marks on our laundry. What should I do?
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
drum is making a knocking sound
