Question about UTStarcom Blitz Cell Phone
Phone shuts off right when i unplug the charger
Everytime i unplug the charger phone shuts off automatically. It turns on when on the charger then dies after like 2 min. i didnt know how to fix it and cricket told me because it had a scratch that they couldnt do anything about it, eventhough i only had it for 3 weeks.so i had to send it to UTSTARCOM and its been a week and still hanbt heard anything back.
Posted by stuckey_h on
Anonymous
    New Friend:
It's a problem with the cpu. It cannot switch over to battery power after the charger is unplugged. its not a hardware problem. I chased every contact point with a multimeter and it all reads as it should. I re-soldered everything, used a diffrent charger, new battery, erased everything on the phone and it still does it. the only constant is the prosessor in the phone. It's a design flaw that pantech built into the phone.
Posted on Jun 03, 2010
Anonymous
Mine did this, too.. I'm not sure what was actually wrong with it, but I took the battery out, blew on the top part (the part that clicks into the phone... it's shaped like those block things on castle walls?), then put it back in, and it's working again. :)
Posted on Sep 16, 2009
Anonymous
    New Friend:
Mine did the same thing! this is crazy i call every verizon place and they cant do anything about it
Posted on Apr 24, 2010
I have a problem getting my phone on. i have a motorola electricify. it wont turn on even when i try to reset it hold the volume down button. it wont do a thing. it wont charge. everytime i plug the c
Kyle
let it set on the charger for a couple hours without attempting to turn it on. See if the battery icon appears.
If that doesn't work you can try MOTOROLA ELECTRIFY Master Reset Factory Data Reset
Mark
Motorola Support
Sep 14, 2014 | Motorola Mobility MB853 Electrify US...
Just charged my new phone but it shuts off and won't work when I unplug charger
Are you shure your charger is working properly? Or that the battery is not shot?
Oct 21, 2012 | Huawei Cell Phones
Laptop freezes everytime when i remove charger...
Try changing the battery, if windows 10, the power settings may need adjusting..just Google power settings windows 10
Nov 01, 2017 | Computers & Internet
When the keys lock, it shuts off
Well i used to have a side kick and my problem was when ever i took my sims card out than put it back in it would delete every thing!!
May 12, 2010 | Cell Phones
All of a sudden my phone just turns off and everytime i turn it on it shuts back off again. Do i need a new phone?
This is usually a sign of the battery not being charged.
It could be that the battery is bad, or the charger is bad.
See if the phone does this while hooked up to the charger.
If you have a car charger, hook it up in the car and see if it works.
If it works with the charger plugged in, it is likely that the battery is bad.
Jan 25, 2010 | HTC G1
Wont turn on unless its plugged into the charger.
maybe their is a faulty with the battery of your phone replace phone battery with another phone with same phone model...if it works fine then just replace to a new battery....or else visit any phone technician to handle it for you.
Oct 28, 2009 | SanDisk Sansa Clip MP3 Player
UT Blitz Has to be charging to work
could be either 1, needs a battery or a 2 new charger, even though it looks like it is charging.
Aug 26, 2009 | UTStarcom Blitz Cell Phone
Everytime it search for a coverage it automatically shuts off
hi friend,
First make sure it's not set to automatically shut off. Go to Options...Auto On/Off and make sure Weekday and Weekend are set to Disabled.
Mine doesn't shut off automatically. However, sometimes when I shut the phone and then turn it back on, the mobile network is not on and I have to go to "manage connections" and turn it on. I checked the options and both weekday and weekend are disabled
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | RIM BlackBerry 7230
Samsung T 809
bad charge not givingit right voltage buy nice new one not generic erther ok
Jan 29, 2008 | Samsung T809 Cellular Phone
Sgh-e315 will not turn on
the phone needs to be reflash so take it to a mobile service center and ahve them reflash it for you.
Sep 05, 2007 | Samsung SGH-e315
UTStarcom Blitz Cell Phone Logo
2,758 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
