Question about Samsung Televison & Video
TV made a buzzing noise then turned off. Now power light flashes
HLP4663W/AA made a buzzing noise for 3-5 seconds then turned off. Now only 3 lamplights flash on the power button. There is no noise when pressing the ON button.
In the past I had intermittent trouble with (1) the TV turning itself off periodically, (2) a couple times the picture appeared in black/white only (no color-strange), (3) in the last 2-3 months the picture would look great at the center of the screen but as the picture progressed (horizontally) outward toward the edge of the screen, people's arms, legs, faces looked became wide or stretched (annoying).
Sorry for the long description and maybe not all of this is related. Could someone give me a wild guess the best place to start? Thnx.
Posted by jwing4maryk on
Anonymous
  • 261 Answers
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Posted on Sep 03, 2009
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
Oct 17, 2009 | Philips 32PT6441/37 32" TV
Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 03, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Screen wont come on
Your color wheel has gone bad. I recommend this repair to only be done by a qualified Samsung service center. Part costs less than $100
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
153 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
