Question about Sony KV-32FS10 32" TV
No picture, every thing else seems perfect
Good condition sound and functional just no picture
Posted by jschlaman on
Anonymous
Picture tube is bad
Posted on Sep 03, 2009
Daniel Augo
    Sergeant:
  • 199 Answers
I suggest that u replace the flyback transformer if this transfomer is licking or damaged do bring behavior of the screen not coming on .
Anonymous
  • 32 Answers
Try adjusting scart leads at back of TV
Picture problems with a Samsung Plasma
This sounds like a short circuit in the color controller circuit board. A capacitor is opening and closing at times and causing changes. The culprit is not a primary component or you would not have a perfect picture at all. The problem requires a technician apply various test to locate the part/s causing the condition to exist. He or She may find and cure the condition on the spot.
My sansui has sound but no picture
My Answer to you> Sound..No Picture? First off...the device or appliance has two separate functions that do not totally unite with one another. True Picture and Sound need to be in Synchronization with each other; but each are independent form each other, as far as circuitry is concerned. Thus; you can have a perfect Picture (VIDEO) and no sound, or visa versa. If the VIDEO is not working, then problems with the video controller exist and this is related to the Picture Control function only. Circuit boards with electronic parts are assembled in a precise order with certain values and purposes. If for any reason one of these components fail the entire Video procedure goes crazy and does strange things. You cannot physically repair the board, and even professional technicians have difficulty doing so. Replacement is the only way to go, or purchase a whole new product.
TV worked perfectly until recent storm... After storm it no longer has sound
as you present. that maybe speaker wiring or speaker have problem. if no . that"be main board not function good . need to replace as posible. good luck!
Remote control(s) suddenly will not operate any function.
How do you KNOW the controller is Good??
There is a little Infra-red receiver behine that little glass window on the front of your TV. This has been known to go bad (assuming all those things are good that you said are good!)
No HDMI audio at all.
Could be lots of things, from bad cable, to your laptop no outputting sound, to your tv not functioning properly. A work-around might be to use the VGA output (and sound output) from your laptop until you can resolve it better.
1helpful
2answers
42 inch LCD Philips TV - TV screen is black, but the sound comes through perfectly on all channels. Same result when a DVD is played into it. Model number 42PFL9632D/79. Plugged into a power centre...
hi sir
this type nof problem occurs mainly because of 3 issues...
1.jungle ic in D -board
2.colour wheel
3.cathgode ray tube/..please check them
thank u,,/please rate it
No Sound
presumably you have already tried powering off for 10 mins then doing a shipping condition reset ?
2answers
Picture on 31KX41K
Vertical deflection problem, stemming anywhere from open windings on the yoke, to a defect in the drive dircuit, sometimes also caused by an open condition capacitor...accordianman
Sony KV-32FS10 32" TV Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
