There could be several reasons why your Crosley washing machine is not spinning properly during a regular cycle. Here are some possible causes:
Unbalanced load: If the load of laundry is not evenly distributed in the drum, it can cause the machine to become unbalanced and not spin properly. Try rearranging the clothes and see if that helps.
Drive belt: The drive belt may be worn, loose or broken, preventing the machine from spinning. Check the belt and replace if necessary.
Motor coupling: The motor coupling connects the motor to the transmission. If it is broken or worn out, the machine may not spin. Inspect the coupling and replace it if necessary.
Lid switch: The lid switch prevents the machine from spinning if the lid is open. If the switch is faulty, the machine may not spin. Test the switch for continuity and replace it if necessary.
Motor: If the motor is faulty or burned out, the machine may not spin. Test the motor for continuity and replace it if necessary.
If you are unsure of how to check or replace any of these parts, it is recommended to consult a qualified technician.
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
You will need to replace the lid switch. Here is the part to order. Below is a video to show you how to replace it. The model may be different but the repair process is the same.
I WOULD RECKEN WHAT YOU HEARD WAS THE BEARINGS IN THE MOTOR GOING AND WHEN YOU TURNED IT ON AGAIN IT SEIZED THATS WHY THERE WAS A BURNING SMELL JUST REPLACE MOTOR
several points.
did you put in transit bolts for move and forget to remove them?
is machine sitting square on all four legs?
is it sitting on a suspended floor? if joist spacing is wide, then this can result in vibration.
