SOURCE: solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Testimonial: "Thanks for your help. Now that problem is fixed I have the added aspect of the "no water in tank" light coming on when the tank is still 2/3 full. "
