Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Have you tried to reset both of the devices? You would want to do the modem first, and then the router. This will allow the router to re-acquire an IP address from the modem. Unless the modem is set to let traffic 'pass through' it should assign an address by DHCP to the router. The router should pick up that IP address and allow traffic to access the internet connection. If not, then you may want to contact your ISP.
