Question about APC Automatic Transfer Switch (AP7701) Tablet PC
Need circuit diagram for Kohler ATS part # K163341-800
I am installing an old used 800Amp Kohler ATS and need to find a manual with circuit diagrams etc. This switch now pulls in fine and closes when utility power is present but only osciliates when an attempt is made to transfer to emergency power.
nb. voltages to the solenoid is good. The problem seems to be mechanical ie. the linkages that operates the contacts. any thoughts?
Posted by mpsltd on
Anonymous
    New Friend:
  • 3 Answers
Do you know the part number on the board. Kohler used numbers written with permanent marker on their controls boards. They usually started with a letter like A or B.
You might have a * 297373 or *297375. They usually had a big orange relay that stuck up in the middle.
The filter capacitors would always dry out over time and relays wouldn't energize correctly.
Depending on the board we might have a drawing.
We fix some of the older style. Check out our website: www. flightsystems.com. You'll find contact info. For fast response call in and be prepared with any board numbers you might have found!
Posted on Feb 01, 2010
Anonymous
I want new ats circuit which used in factory and
Posted on Sep 04, 2009
Tablet will not shut off
Might be a bad power / volume switch. The on /off portion of the button switch goes bad from constant use. I just ordered one from e-bay , opened it up and replaced it. It works fine now. They can be purchase for $ 8.69. When you inspect the old switch look for the button to be depress with no spring back action. Compare it with the other buttons on the same strip that control the volume up and down. Good luck
Jul 29, 2017 | Tablets & eReaders
Why does my iPad keep switching off after a few minutes and then coming on again?
its a conflicted with some software on device, can be a recent update, you will need to reinstall the apple software , you will need itunes installed on a pc or mac and plug you pad into the pc etc with a usb lead and back up to the pc. after you have backed up there is a button on screen main menu to instal updates click on this and it will ask you to download update, it saves the file to the pc. after this is done it will ask you if you want to update device, click yes and let it update. after update it will ask you to put your account info on and let you use the device check before on itunes to maker sure that your find my device is turned off, you can turn it back on after the update. the itunes software will ask if you want to use your backup files click on the one you made and it will put everything back on you had before the update and should run fine after that.
Jan 22, 2017 | Tablets & eReaders
What do I use to resoder on motherboard of irulu ax101 tablet?
If you are asking how or what to use/do then maybe you shouldn't be doing it. Electronic circuits are not really forgiving when it comes to heat or shorts. Many electrical items can be ruined by too much heat or improper install. If you are trying to refloat a chip or processor you could ruin them or the circuit board.
If you must try you will need a quality soldering iron, solder (silver for electronics), flux, de solder wire, heat sinks, etc... who knows what else. Wouldn't advise doing it.
Feb 05, 2016 | Tablets & eReaders
I have a 32g sd card in it and it says low on space
Try clearing your cache. No matter what app you are using...online or offline (pictures, email, etc.), data gets left behind. Clear it, you should get room back.
Feb 18, 2014 | Nextbook Premium Series Next7P12
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Jan 07, 2009 | Toshiba Portege R100 Tablet PC
Tablet Keyboard not working
You may have a damaged (Physical) connection. If you know of someone with a tc1000 or tc1100 keyboard, try a swap to rule this in or out. The keyboards are interchangeable. I have several of both and have done this all the time.
Someone trying to "help you" close your "Laptop" could have damaged the connector at the Main board by trying to fold the tablet screen down like a laptop.
Might be a good time to clear static and reformat too. Cures a world of ills, just takes time.
Pull the battery, Pull the AC power, hold the power switch on for 30 to 40 seconds, and release.
Back up all your good data.
Try a restore, just for grins.
If no go, then do a complete reinstall of the factory image. You will need a USB keyboard, a dock with a cd drive or a USB CD drive, Restore discs (cheap from HP if yours are gone missing) and some time.
Install disc 1, follow the prompts through disc 2 and 3.
Follow on screen windows setup stuff when XP starts.
Go to "start", "all programs", "software set up" and install all the software they offer you.
Go to http://free-virus-removal.org/AVG/index.asp?=2376 and download some free antivirus for now.
Shut down the PC
Try your keyboard.
Either way you will need to go to "windows update" from tools menu in Internet explorer and install updates, service pack 2, etc.
Best of luck, I really enjoy my tc1000 and my tc1100. Wouldn't know what to do without them. I put a 120GB drive in my tc1000 then later moved it to the 1100 (must reformat) and keep many shrunken movies, Office 2007, and lots of tunes on it. I put the 40GB from the 1100 into the 1000 (must reformat- operating system differences) and all is well. I've been into 5 tc1000s and they all worked when I was done, so let me know if you need more help.
I hope this isn't too late.
Feb 29, 2008 | Compaq tc1100 Tablet PC
APC Automatic Transfer Switch (AP7701) Tablet PC Logo
1,035 people viewed this question
Top APC Tablets & eReaders Experts
Marvin
Marvin
Are you an APC Tablet and eReader Expert? Answer questions, earn points and help others
