Ice maker ceased to function. Am also unable to remove ice bin.
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
SOURCE: i have a Whirlpool refrigerator
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position. If it doesn't want to move don't force it. Try shutting the ice maker off in case the arm is frozen in the up position. After the ice maker defrosts a bit try again to move the arm gently.
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
