SOURCE: No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
SOURCE: I need to know step by step how to hook up my
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
SOURCE: some of my channels have
Usually Faders 10KD stopped working, very easy to replace. The faders can be purchased directly from Mackie. Faders are available also on Full Compass on the below website:
https://www.fullcompass.com
