Question about Watches
I need some informations about the following 2 old watches v2300090. 512209 and v2320080 6N4767 . Thank you
PulsarXII quartz 512209 and Pulsar XII quartz 6N4767. Can they be fixed ?
Posted by Kim H on
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: cover on 20 year old Pulsar pocket watch won't
Most likely the spring which locates at he cover hinge pin is either bent or broken.
Posted on Aug 23, 2009
andrew wright
  • 56 Answers
SOURCE: New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Posted on Jan 24, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: i have pulsar quartz alarm chronograph water 100m
This watch does not cost a lot - in very good state you can fetch $40-$80. But this is ONLY if someone is interested in it. If not - your watch cost nothing (sorry to say that). Pulsar has never been desirable watch make, so, there is no interest in this make. Now Pulsar is taken over by CITIZEN for a low priced watches for middle class people, but because it is now under CITIZEN name, it may gain some value. Do not be upset with the info - someday, somehow your watch can be collectable. Rate me, please, accordingly to the info - not your feelings about the info.
Posted on Feb 05, 2010
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: Need instructions on how to
Some of these can be quite a bugger to set, there are so many variates of Pulsar watches, and I'm not able to locate exact instructions for that model. However if you call Pulsar with that model number they will gladly provide a free manual for you, one you can probably even download and view, or they can email it to you directly. Please call Pulsar at 1-201-529-5730 and request the instructions.
Thanks
Tim
Posted on Sep 23, 2010
Ekse
  • 13434 Answers
SOURCE: My Pulsar solar powered watch
Hello, and thanks for using FixYa.
unfortunately it is very difficult to identify the watch based on those details. Just open the back cover and see what battery is inside, often its a very small battery that costs a few dollars.
Posted on Oct 22, 2010
HOWDO I SET MY PULSAR QUARTZ ,PULSAR #114302
Try Googling (pulsar)(114302)(manual) without parens for instructions.
Aug 06, 2017 | Watches
What does this Y148-8009A1 and 491300 mean on the back of a pulsar P watch
Y148 is the quartz movement model, 8009 is the case number.
The 491300 is the serial number, which means that the watch was produced in January of either 1994, 2004, or 2014. I have no idea what the A1 in a box is for. I hope this helps.
May 31, 2016 | Pulsar Watches
No work quartz
This watch is kinetic, in that a moving rotor inside the watch powers a rechargeable battery that runs the quartz mechanism. You should not need to attempt to open the watch! It may be that the battery is flat (especially if it's not been worn for a while) - you can try swinging the watch back and forth to charge it (check online for charging instructions for Seiko or Pulsar kinetic watches). If that fails, take it to a reputable establishment for repair.
May 22, 2016 | Steinhausen Stahlhammer Dual Time...
Number on back plate 142021. Can you tell me more about it?
This is the serial number. It tells you that the watch was manufactured in April of the first year of a decade (e.g. 1991. 2001, 2011 etc). If it's a quartz watch, it's probably one of the example years shown.
Apr 21, 2015 | Pulsar Ladies Watch
Lost stem on watch. can i get replacement? can i install myself?
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
Feb 05, 2011 | Pulsar PXH227 Wrist Watch
When I started wearing the watch it would stop at least once a day and I would have to pull out the reset time button, fix the time and push the button back in again to get it started. It happened 4 days...
If it's a quartz watch, replace the battery. If it's a mechanical watch, even a "self-winding" model, wind it manually - unless you're very active it needs a manual winding if you don't wear it all the time. If it's more than a few years old it may need cleaning by a watchmaker.
Apr 09, 2010 | Pulsar Bracelet PXQ502 Wrist Watch
I have pulsar quartz alarm chronograph water 100m resist.number v600-6010 551263. how old and how much did it cost
Feb 04, 2010 | Watches
Watches Logo
149 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
