Contrast Ghost Mine is a monitor of Brand HCL. Its Model no. is HCM782M. The Contrast is coming on the screen again and again. Sometimes the menu pop's up and sometimes some options like H-size, Rotation, Brightness, V-size, V-centre, etc are automatically selected and are automatically changed to 100. It doesn't even realize its user is not wanting to increase but it increases on its own. Please Experts, what to do. NOTE:- There are no stuck keys.
  • Anonymous Sep 02, 2009
    No sir, it was never cleaned with a window cleaner nor the monitor was dropped. It started after 2 years.. Can you suggest me something else.
  • 615 Answers
This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Good Luck
Posted on Sep 07, 2009
Testimonial: "Hey chandra, answered me again. Ok thanx, for your time."
    Master:
    Sergeant:
  • 460 Answers
It is a menu button problem.you can hold this button by pin or you can repaire it.
  • 788 Answers
If you are sure about the sticky keys, it sounds like the unit may have been smacked or dropped.
Maybe someone has spayed it with window cleaner or something damp or wet ?
Posted on Sep 02, 2009
6ya staff
SOURCE:
I have a HCL Monitor Model HCM782M.For the past 2 years since i bought it the screen was fine.But now the screen shows the CONTRAST SETTING everytime I boot my pc and keeps up popping up ver very qucikly.I...
Mr Ajit in my organisation I have around 20 such monitors which have the same error. This happens due to moisture the mewnu PCB gets shorted and now you are left with only two solution either disconnect the menu pcb from the main board or replace it with a new one
Aug 17, 2010 | Computers & Internet
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Contrast Blinking !!!
its a harware issue nothing much can be done from your end really.......right time for hardware servicing
Sep 03, 2009 | Computers & Internet
Monitor Reset Instructions
it is a setting button problem. pls checked this button.
Aug 31, 2009 | Canon Pixma MP450 All-In-One InkJet...
Monitor problem
Welcome to Fixya Customer support
Good Luck
Aug 10, 2009 | Computers & Internet
MONITOR DISPLAY
This will be the nth time you posted the same problem. On your earlier postings and Ask Mes, you were already provided with three (3) probable solutions:
  • cleaning;
  • placing a paper insulator;
  • checking the logic controller (D/A) converter.
And you have done the cleaning only! As likewise noted, HCL would appear to be a limited and regional/domestic model, since you are in the same region, you would be more in a favorable position to secure detailed technical information as to how to resolve the issue.
Perhaps the best approach would be to seek additional technical information within your region, follow the outline/suggested procedures and report to results/status of each.
Incidentally, I am not sure how it is in your country, but I believe it is customary to at least say Thank you especially when asking the same thing over and over again with each time being attended to. So Thank you for using FixYa and good luck with your concerns.
Nov 18, 2008 | Computers & Internet
CRT MONITOR display
It sounds like this monitor may have what's called the "Windex syndrome" in TV repairs. If someone cleans the screen with a spray cleaner and it drips down the face, it can get onto the circuit board and cause intermittent button troubles. Sometimes it's possible to clean off the corrosion from that area, but the most reliable fix is to clean the board, replace the switches, and remove, check and if necessary replace any resistors connecting to the switches.
Nov 18, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor display
Appreciate the direct "Ask Me"
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Computers & Internet
Display on menu
Hi again,
It would seem that you posted your problem several times. As stated in my proposed solution in your other postings:
Computers & Internet Logo
378 people viewed this question
Ekse
Marvin
Marvin
