SOURCE: Hp dv1000 no backlight, repalced inverter, still no screen
plug in a monitor in the side of the laptop if it shows up then the lcd is bad. Also try and reset the memory by pulling it out and then put it back in if not in all the wall nothing will appear on the LCD.
SOURCE: emachine backlight or inverter. How to replace it.
I suggest visiting a specialist and not doing this by your own.
SOURCE: I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: How can I get my backlights to work on Samsung LCD tv
If your not a TV Engineer , get one to look at it , as you may keep changing the incorrect part.
