Question about LG Washing Machines
I had to replace an LG dryer with a KenmoreSteam Dryer 7968138. Can I still use my LG WDP3W pedestal?
Posted by AngeloGallego on
Virendra Kumar
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Need to replace
Posted on Jul 19, 2019
  • robert Jul 19, 2019
    I think you can
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: REMOVING PEDESTAL FROM DRYER FOR STACKING PURPOSES
if you pull the draw out and lay the washer on the back you will see the 4 SCREWS to loose . if is not too late for you
Posted on Dec 23, 2007
Anonymous
  • 1028 Answers
SOURCE: kenmore pedestal for the front loading elite washer and dryer
some pedistals have a screw on drawer just behind front on end of rail newer ones have a small black lever on each side ..pull drawer completely out lever is about midway at end of inner rail pull lever 1 up other down drawer will pull off rail reinstall by sliding rails back together and pusing all the way in
Posted on Jun 11, 2008
Anonymous
  • 12 Answers
SOURCE: Installing pedestals for washer and dryer
its not but it is a 2 person job, the washer is in excess of 200 lbs and must be lifted onto the pedistal, after that its just a few brackets and philips screew to secure it.
Posted on Feb 07, 2009
Anonymous
  • 360 Answers
SOURCE: I have front loading washer/dryer;need to install pedestals.
Yes!!!! Do not lay the machines on their backs with out the shipping bolts/hardware installed..Major damage will occur!!!!!
clarkco
Posted on Feb 28, 2009
Sheldon Dedek
  • 909 Answers
SOURCE: Samsung Dryer keeps tripping the circuit breakers
The "professional installer" likely set the pedestal on top of the power cord and damaged it, or the dryer duct has been pinched off causing the dryer to overheat.
Posted on Jun 13, 2010
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
The soap compartment has water left in it
does the unit work? if so, dun worry about the water. unless the soap has not been gone into the wash?? do not use powder! these are liquid soap washers! lol.
Apr 13, 2014 | LG 14-inch Front Load Washer/ Dryer Top...
How do you lower the height on a LG washer and pedestal? It's too high by 1" to fit under my wall cabinets.
The pedistal has 4 leveling legs on the bottom of it you can adjust to a certain point. You may have to take the lefts off completely and if it still doesn't fit, you unfortunately didn't measure properly.
Mar 16, 2013 | LG WDP4W 14 inch Pedestal White
Problem installing a pedestal on a cabrio dryer
We'll be glad to further review your concerns. Please email us at [email protected] at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 10, 2018 | Whirlpool Dryers
Are LG washer/dryer pedestals a bad idea? We have an LG washer and dryer in our garage on concrete and have no issues with vibration. We recently purchased the pedestals for these and have been warned...
On a concrete floor these pedestals have a greater success than any other flooring. Nevertheless, more shaking will occur. One solution that has worked is installing "shake away" rubber pads with the pedestals. Not sure if there's an appliance parts store near you that carries this product. But like I said earlier, the fact that they are on a concrete floor helps.
Sep 28, 2011 | LG WDP4W 14 inch Pedestal White
How do I connect the dryer to the pedastool?
Hello- The Pedestal (depending on the make and model) usually connects to the dryer by unscrewing the dryer legs and using the bolts that came with the pedestal to screw through the pedistal into where the dryer legs, feet, were. This should be done with the dryer laying on its side. If you didn't get instructions with the pedestal then I would contact the manufacturer and they can email them to you (different brands have different systems). Good luck and best regards.
Sep 27, 2010 | Dryers
Jun 13, 2010 | Samsung DV448AGE Gas Dryer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Getting heavy dose of overcharge est.coverting to LP gas!
Taking this dryer apart for the frist time is quite a job.
You should really let a pro.do it.
It was a lot easier back in the day!!!!!
Jan 14, 2010 | LG DLGX7188 Gas Dryer
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
