My GE Profile Quiet Power III Model # GSD4330Z00WW does not drain. I want to clean the filter, but can't find any information on line that helps me figure out how to do that.My GE Profile Quiet Power III Model # GSD4330Z00WW does not drain. I want to clean the filter, but can't find any information on line that helps me figure out how to do that.
You can't post conmments that contain an email address.
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
