Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The printer cannot feed the paper from the rear tray, makes terrible gridling sound, then stops working and on screen appears the 5700 error code.
Posted by Mari?n Bra?ok on
  • Mari?n Bra?ok
    Mari?n Bra?ok Sep 03, 2009
    Not helpful. replacing the feeder is what I dont want to do, I want to REPAIR the feeder, im searching here for possibilities. The casette feeder is working properly, just the rear tray strikes.
techster04
  • 155 Answers
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Posted on Sep 02, 2009
  • techster04 Sep 03, 2009
    It is better that you take it to an expert.
tontengman
    Habit-Forming:
    New Friend:
  • 7 Answers
Error 5700 pertains to the error in the rear tray feeder. The plastic triangle part inside the rear tray feeder (this part pushes the paper rest backwards) has cracked.
Solution:
Remove this part and try to repair it by using a strong adhesive.
Posted on Jul 16, 2012
Ive got a canon MX700 with an error code 5700 can you help.
Generally, the 5700 error idicates a faulty paper sensor. But this error can crop up if the paper feeding mechanism is faulty/obstructed as well.
Ensure that there is no obstruction in the paper feeding mechanism. Look for bits of paper or debris between the rollers.
Or you can try a hard reset: Unplug adapter from printer, hold down the power button and replug.
Should that not work, you may want to consider getting it serviced.
To contact Canon for a product you currently own:
Email:
Click here for support via email.
Phone:
1-800-828-4040
May 11, 2008 | Office Equipment & Supplies
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Cannon MP 250 crayon stuck between rollers
Description
Cleaning the Paper Feed Roller - MP250 / MP270
Solution
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and remove any paper from the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Clean the Paper Feed Roller.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4. Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
If the problem is not resolved after cleaning the Paper Feed Roller, contact the service center.
NOTE:After the cleaning is completed, press the Stop / Reset button to return the LED to the copy standby mode.
Oct 28, 2017 | Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
4.Clean the Paper Feed Roller with paper.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 5700 displayed on copier screen
i forgot to mention that my printers a pixma MX700
Jan 06, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
5,094 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
