Question about IBM 6400 Matrix Printer
How do you change the IP address on an IBM 6400 printer
Posted by sexyscorpio2 on
Bill Schilz
    President:
  • 2,049 Answers
The IP address is usually assigned by your router using DHCP. I assume you are trying to print to the printer from your PC and it won't go. Go into your router using IE and look for the IP address assigned to the printer and write it down. Exit IE.
Next, go into Control Panel>Printers and choose the IBM printer. Go to Properties and choose Configure Port. Enter the correct IP address, hit apply and exit. You should be able to print to the IBM now.
Posted on Sep 02, 2009
Barbdos
    Novelist:
  • 93 Answers
Hi !!
There is no 'standard' way of doing this - it varies from printer to
printer.
Typically a network printer can be set to get its IP address from a DHCP
server. I guess yours cannot.
Here's what you need to do:
Change your DHCP scope to 192.168.1.2 - 192.168.1.249
we'll reserve 192.168.1.250 for your copier/printer
Telnet into your copier/printer
At a command prompt enter the following command:
telnet 195.195.195.x
Substitute x with the proper value
You should see something like the following:
Welcome to XXXXXX-X
Enter username, or HELP
Enter su
At the Server prompt, enter su again
at the password prompt enter system
"system" is default super user password which does not echo back
Server
to define Subnet Mask enter:
serverdefine subnet 255.255.255.0
to define ip:
serverdefine ip 192.168.1.250
to verify:
servershow server config port 1
to logout:
serverlogout
Hope this will help !!!
Regard's
2 Related Answers
Muggs01
Muggs01
  • 72 Answers
SOURCE: Just moved IBM 6400 dot matrix. Need new IP address.
it should have kept the same address
Posted on Jan 19, 2009
LineMatrix
Toby
  • 34 Answers
SOURCE: how to i change the ip address of an ibm 6400
Here is the procedures for entering the IP Address thru Control Panel...
Have any question, you can call 972-907-9771 x311...
Posted on Sep 10, 2009
Ibm 6400-08p matrix printer service centre in tamilnadu where?
Might not find any anymore, IBM has discontinued and no longer supports the IBM 6400 series printers and or any printers at all. If you need some support or printer parts please contact me. Rory 708--597-4222
Sep 15, 2011 | IBM 6400 Matrix Printer
I need to change the ip address on this printer
Hi
Open the internet explore and type the previous and press enter.exp 192.168.1.10, go to the network setting and set the ip address whatever u want, and save and restart your printer.
May 13, 2011 | IBM Infoprint 1140 Laser Printer
I need to add IBM Infoprint 1116 to my home network using IP address. How can I change already setted IP and gatway addresses on it to needed?
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | IBM Infoprint 1116 Laser Printer
How to i change the ip address of an ibm 6400 printer
Sep 02, 2009 | IBM 6400 Matrix Printer
Switch to LPT1 from my computer
Go to start - settings - printers and faxes
Right click on your printer - click properties
At ports tab change from tcp-ip to LPT1
Click apply
Don't forget to connect your printer with parallel LPT cable
Jul 24, 2009 | IBM 6400 Matrix Printer
Need to change the printer ribbon on ibm 6400
BY WWW.IBM.COM/SERVICE
GO ON LINE AND TYPE THE FOLLOWING:
HOW TO CHANGE A PRINTER RIBBON IBM 6400
BEFORE YOU DO ALL THAT FIND THE RIBBON BOX AND SEE IF IT HAS ANY TYPE INSTRUCTION WHAT TO DO?????????
ROD
May 12, 2009 | IBM 6400 Matrix Printer
I have a 30H4054 and need to change the IP address
After moving to a new location that had a new IP address, I found I was unable to change the IP address within the 30H4054 so we took the printer back to where it was installed and working before and someone changed the IP address there then brought it back to my new location. So ....have the IP address changed before you move.
Apr 14, 2009 | IBM (30H4054) Print Server
I need instructions for tractor replacement on IBM 6400 printer
GO ONLINE ASK THE FOLLOWING:
WWW.IBM.COM/SERVICE
IBM 6400 TRACTOR REPLACEMENT INSTRUCTIONS
SERVICE MANAUL IBM 6400 PRINTER
IBM 6400 TRACTOR ASSEMIBLEY/DETAILS
ROD
Apr 02, 2009 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer Logo
2,143 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
