Question about Konica Minolta magicolor 2300DL Laser Printer
Miss feeds when print multilpe pages
When printing multiple pages, paper feeder starts to pick up next sheet before first sheet has cleared, causing paper a jam.
Then next sheet starts to feed when the first sheet is about 75% fed, this causes a long continous sheet of paper without the letter sheet break.
All setting on drive are set for letter size paper. It seems to have someyime to do with the timing of the paper feed tray timing, when it starts to feed the next sheet of paper.
Please help.
Thank you in advance
Posted by artist200420 on
Craig Gillette
    President:
  • 2,306 Answers
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Posted on Sep 02, 2009
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Paper won't feed through to print my faxes.The mechanism sounds like it is turning to pick the paper, but it isn't feeding through. As an alternative, can I use the USB port to copy the faxes onto a USB...
That model quite often breaks plastic parts that hold the gears together in the sheet feeder, a new sheet feeder will run around $49.00, there's no way to transfer faxes out of the machine without printing.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Aug 05, 2008 | Office Equipment & Supplies
Legal paper
Legal size paper must be loaded into the automatic sheet feeder (ASF) in the rear, and the Feed Switch used to set Auto Sheet Feeder.
For printing, in the Printer Properties (or Printing Preferences) dialog box, select the Page Setup tab, and set the Paper Size to Legal.
May 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper will not feed
These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
Konica Minolta magicolor 2300DL Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
