I NEED HELP REPAIRING MY I9 SCREEN
There are basically two ways to do this. You can get online to the Java website via your WAP browser and enter in the code for the CECT installation ((wap.GetJar.com and then quick the download code 30827.) I usually download via USB though as this puts a copy onto my computer (in case it accidentally gets deleted) and it doesn?t cost any money or data to do this.
For the Java installation, go to the get jar website. Make sure that you have the device set to CECT A100 (the CECT default.) Connect the phone to the computer via USB. Hit the mass storage icon on the phone. Click on the jar file that you want to download. Click save. Next, find the drive that your phone is listed under. (For me, this is K:/, but it may be something different in your case.) Click OK.
Then, unhook the phone from the USB. Go into the document icon on the phone. Find the received file and then scroll down until you see the browser and click it. Then click ?install.?
Now, you?ll go into Java icon. You?ll see the browser in the list of Java files. Then click launch. Opera should launch and you can start browsing.
Most often, when something goes wrong here, it?s because the data, WAP or Java settings aren?t correct. You?ll need to go in and set them up depending upon your carrier. For example, if you use T Mobile, you?ll need to input the T Mobile WAP, port, and data settings. Typically, you set the data first, then the GPRS, the WAP, and the MMS. Finally, go into the JAVA settings and make sure that T Mobile (or AT&T, or which ever carrier that you are using) is reflected. There are many resources that will give you the Internet settings for almost every applicable carrier that you can think of. If for some reason you can?t get online, I?d check to make sure the phone isn?t set to the original Chinese or factory settings.
To view video, close up photos, full specifications, and real time rock bottom pricing on the CECT i9 please check out http://i9clonephonereview.com/
If you need a USB cord for the i9 (or other accessories including internet, MMS, or WAP set up instructions, cases and skins, unlimited data sim cards, memory cards, batteries, etc,) please visit http://i9accessories.com
