Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sensors The sensor fell off and I don't know which wire goes where????The wires are white ,yellow,and red.On the sensor itself it has a screw that says white but the yellow wire was connected to that one. The other wire was broken and I don't know what color goes on that screw marked black .Would it be the Yellow wire OR red wire. Please help Thank you
Don Maggard
    President:
  • 3,197 Answers
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Posted on Sep 02, 2009
Testimonial: "Thank You I got it working!!!!! Thanks for the help"
How do I know where to hook wires p on model 621MM master mechanic door opener
Your wires should be color coded blk/ white & solid white you will have a pair for each sensor twist the white wires together and twist your blk/wh wires together now on the back of the opener you should have three screws connect whites to the middle screw a(2) and your blk/white to the third screw (3) your sensors should light up now u should have a solid whte and red/whte connect red/whte to #(1)screw and white to #(2) your wall button should be lite
Mar 06, 2015 | Sears Craftsman LiftMaster Chamberlain...
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Hardware & Accessories
The manual says wire black to black and white to white and ground to green screw. The box i am wiring into has a white a black a ground and a red. What do I do with the red wire?
Depending on where box is and who wired it the red wire very well may be switched from inside. If you want to use the dusk on and off and sensor exclusively, in other words, you don't want it switched, cap off the red wire and don't use it. If you would like it switched, see if you can find a switch that will operate the red wire, probably somewhere around the nearest doorway out, or if you have a switch that you could never figure out what it was for.
Apr 30, 2011 | Heath Zenith All Metal Motion Sensor Light...
I need to know which wire on the 4 wire oxygen sensor (2 white, one grey one black) is the heat wire on a ford f-150 o2 sensor?
Hello! There are four O2's...Each O2 heater, left and right bank, front and rear, has it's own wire colors...These colors are "at the connector"...First series are the control ground sent by the PCM..
RR=White/Black...RF=Red/White...LR=Tan/Yellow...And LF=Yellow/Light Blue...........This series are the battery leads, hot when fuel pump relay pulls...RR=Violet/White...
RF=Red/Yellow...LR=Violet/White...LF=Red/Yellow...
If you have any questions feel free to ask...Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Oct 20, 2010 | 2001 Ford F150 Styleside SuperCrew
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: I'm tryin to connect the sensors on my garage open...
IF YOU HAVE THREE SCREWS THE WALL BUTTON GOES TO 1 AND 2
THE EYES
THE WHITE WIRES W/BLACK LINE GOES TO 3
THE PLAIN WHITE WIRES GO TO 2
IF YOU HAVE SLIDE IN QUICK CONNECT THE WALL BUTTON GOES WHITE WITH RED TRACE TO RED.
THE SAFETY EYES WHITE WITH BLACK TRACE GOES TO GRAY PLAIN WHITE GOES TO WHITE
HOPE THIS HELPS
May 18, 2010 | liftmaster Chamberlain Garage Door Opener...
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
I have a 2000 dodge dakota and i bought a universal h20 sensor and i need to know what the wireing digram for the sensor is the colors on the truck are orange/green and yellow/white and black/blue and...
Ok, the truck - org/grn goes to one of the sensor heater wires (wht).
The truck - blk goes to the other sensor heater (wht).
The truck - blk/blu goes to the sensor ground (grey)
The truck - yllw/wht goes to the sensor signal wire (blk)
Apr 07, 2009 | 2000 Dodge Dakota Quad Cab
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
161 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
