Is there a problem using the Bytec BT-144 External Floppy Drive on a computer running Vista? If so, what do I need to do? T
he CD-ROM which came with device seems to have support for pre-Vista only.
I originally used the plug-n-play without any apparent problem, but the word processing program I installed with the BT-144 is not working properly, leading me to suspect I may need a new driver for Vista.
THANK YOU!
If you installed a program with the drive, th edrive is functioning properly. If the program will not run, you need to check the program compatibility with vista or investigate any errors you are recieving.
The 1.44 floppy drie I ordered did not have any instructions. I am using a new HP laptop with windows 7.
