You have two timing marks one down on the crank pulley the other on the v/c remove plastic covers there is a little notch in the v/c. make sure the cam gear and crank pulley both line up. before you remove the belt. de-tension the tension roller. You will need a long thin screw and 5-6 thin large round washer to push down on the tensioner. good luck
