Question about Omega Easyshot Staple Gun & Desktop Stapler
Won't shoot staples. Proper loading instructions please.
Posted by zelgadis26 on
Anonymous
  • 3 Answers
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
Posted on Sep 03, 2009
How to shoot staples out of a trutac staple gun
Hello, there. The TruTac (TT50) is a bottom load staple gun. This video on the TruTac (TT50 and TT21) may help to answer this and other questions: http://bit.ly/1Xv7jeZ. Once the staples are loaded, keep the tool flush with the surface while stapling. If you have any more questions or need more detailed instructions, please contact us at [email protected] Thank you!
Jun 07, 2015 | Arrow Fastener Staple. TruTac Forward...
Why won't Easy Shot staples advance/shoot?
Hi Elaine, The EasyShot stapler is a bottom load stapler. Please follow the steps below to make sure you are loading the staples correctly.
- Turn the tool upside down so that you can read the text "use light duty narrow crown" on the bottom of the magazine
- Open the magazine of the tool
- Place the staples inside the channel (not on the back of the magazine rail)
- Close the magazine.
Attached is a picture so you can see where to place the staples.
If you are still having trouble please contact our customer service department and we can assist you further.
[email protected]
Thanks
May 29, 2015 | Staples Tools & Hardware - Others
HOW TO LOAD BRADS IN STANLEY TRE500
Please download the instruction sheet from the following link which explains how to load the brads. Make sure you have the correct size of brads mentioned at the bottom of the instruction sheet.
TRE500 Sharpshooter Stapler Instruction Manual
Aug 13, 2014 | Electric Stanley Tre500 Staple Gun /...
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Jan 07, 2013 | Duo Fast Duofast Carpet Pro Electric...
I have a Fasco F1B7C-16 upholstery stapler that won't shoot. There's no mechanism to push the staples forward -- is that normal? The instructions are completely useless ... Help!
The staples are loaded in from the bottom of the unit.
Pull out the staple tray all the way to the rear then turn the unit upside down and drop the new staples into the grove in the unit.
Push the tray back into the unit and you are ready to go!
Dec 03, 2011 | Fasco Tools & Hardware - Others
Staples are loaded and won't shoot
check for a jammed staple near the end. This often happens and prevents the staple from feeding all the way
Sep 17, 2011 | Garden
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Omega Easyshot Staple Gun & Desktop Stapler  Logo
4,907 people viewed this question
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
