Depending on the configuration,if you have installed a video card,and if it has a dvi connection thats the one to use, by default once a vedeo card is installed it automatically disables the onboard card which may have the blue connector,so the answer is once you have a dvi connector on the backside thats what you should use
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
no worries, any monitor you buy now which is an LCD has both inputs DVI and VGA. However, it might not necessarily provide both cables. I suggest you buy one where both cables are included.
From the description, the cable you have is VGA. The VGA PC interface for it should be smooth with small holes in it. The DVI PC interface is wider than VGA
You can buy like this connector to connect your New Monitor to your Dell Dimension 3100.
It's in the market and its cheap.
DVI VGA Gold Cable
DVI VGA ConnecHi,how do I know wheather I need DVI or VGA cables - 4306904.jpgmg src="/uploads/images/4306904.jpg" alt="4306904.jpg" class="h_mi" />
It will help you a lot to use your old PC.
Please rate me.
Http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
http://www.tvone.com/images/1t-vga-cattx-rear.jpg
See which one you have. There are VGA to DVI adapters you can purchase in case the computer output is different form the monitor input.
