Our 2-line stunt kite goes up, but then almost immediately crashes. How can we keep it up in the air?
Unless there is a problem with the kite itself. Look for broken or bent connection bars. If there seems to be nothing wrong make sure you are somewhere with lots of wind. like the beach 10-15mph winds at least. Make sure the string is let out in equal lenghts (Most likely your problem) and just let it fly for a few minuts before attempting any tricks. If you can get it up and there is plenty of wind but it keeps crashing then add a tail to give the "bottom" of the kite some extra weight. Good Luck.
Testimonial: "Thank you very much; I'll try these tips!"
Kites, especially stunt kites are very sensitive, be gentle with the controls. Also if you are unwinding the lines, make sure they are of equal length and use the full length, the shorter the lines the more reactive the kite will be and so harder to control.
http://www.thekitesurfcentre.com
Two handles, each on it's own kite line.
do you have one or two handles?
