Computers & Internet Logo
Question about Samsung Computers & Internet
I have a samsung computer series 7 700G7A/700G7C. I need to know where to buy a battery, AC adapter,power cable for this computer
Where can I buy a battery, A.C. adapter and a power cable for my computer 700G7A/700G7C
Posted by ANITA Laurin on
  • Patrik Parker Jul 18, 2019
    Hi ANITA Laurin, I want to help you with your question, but I need more information from you.
    Please Call Customer Service & Support For Help Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 382 Answers
SOURCE: My Computer doesn't recognize Ion 320 GB Harddrive
Well if its lighting up, then the drive is receiving power, or the enclosure atleast. Forget that case, extract the drive, and seek out something more reliable and more solid. Preferably an aluminum enclosure with no fan.
seek out Weibetech.
Posted on Oct 23, 2007
Anonymous
SOURCE: Viewsonic VP181 power adapter barrel jack size
yes. it is a 5mm center hole
Posted on Dec 18, 2007
Anonymous
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
Anonymous
SOURCE: Screen went black
Just a thought... There's a "Fn" Key located beside the Start key, when you press this "FN" key + F5, the screen goes black, and if you press again, the screen goes back to normal... Could this be the problem?
Posted on Jan 03, 2009
Anonymous
SOURCE: Shark cordless 15,6v need to buy ac adapter Ktec KA12D220020034U
need a Ktec ac adapter listed above. KA12D220020034U. HOW MUCH FOR THE ADAPTOR AND HOW SOON CAN I GET IT.
Posted on Mar 25, 2010
Fault finding
What! !O_O!
For a statement, such as, "Motherboard not on", you would be stating the motherboard either does not receive power, or the motherboard does not use the received power.
Primer:
You press the Power On button. The first chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor (CPU) on; and hands the computer over to the Operating System. (In this case a version of Microsoft Windows)
If the statement is the motherboard is not turning on, you are in effect stating the BIOS chipset is Not receiving power.
Diagnoses must start from the AC adapter (Charger) You need to know if the AC adapter is putting out the correct Voltage. Also while testing have an assistant, gently wiggle the cable FROM AC adapter TO laptop; and power cord TO AC adapter. Any fluctuation in the reading, means a broken wire.
AC adapter proves to be good, the diagnoses goes to the DC Power Jack. The DC Power Jack is the jack on the laptop, that the AC adapter plugs into. (DC_IN)
AC adapter removed, Battery removed; a small instrument is used to see if you can gently move the DC Power Jack. ANY perceptible movement means a bad DC Power Jack -> Replace.
DC Power Jack checks out OK, then the problem will most likely be the Power MOSFET's on the motherboard. They determine if the Battery is to receive a trickle charge, or full charge. Also determines if the laptop is to run off of the Battery, or just the AC adapter.
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
I can give a lot more, than the generic information above, if I had the Model Number of the Acer laptop. This is on the Bottom of the laptop. Post back in a Comment.
Regards,
joecoolvette
1helpful
R519 move ac power cable light flicker on/off
This could be an AC adapter problem.Use another same rating adapter for teating.Check your ac adater volt and ampere at output terminals using a good quality digital multimeter. If OK, check the battery also. Then only suspect motherboard and power jack. Hope this helps
No power on my samsung rv510
Zinzee, check the AC adapter first. (Charger)
Wiggle the power cord from AC adapter to surge protector.
See if the AC adapter LED power on light, blinks.
Yes? Bad power cord.
No change?
Go on.
The port on your laptop that the AC adapter plugs into, is the DC Power Jack.
Wiggle the cable from DC Power Jack to AC adapter.
Power On LED light up, or blink?
Change? New AC adapter. (Also need to check DC Power Jack center pin, to ensure problem is cable, not DC Power jack)
No Change?
Go on.
Unplug the AC adapter from the surge protector. You will need a multimeter now.
An economical multimeter can be purchased for as little as $5 to $12. Available at a multitude of stores. An auto parts store is but one example. (Not for $5 probably )
The Function Knob is set to DC Voltage. (DCV)
If just a symbol it is a dotted line over a solid line.
The center hole in the plug of the cable that goes to the DC Power Jack, is the Positive connection. This is where the RED probe lead (Positive), of the multimeter goes to.
The outside cylindrical metal shell of the plug is the Negative connection. This is what the BLACK probe lead (Negative), touches against.
You should read very close to 19 Volts (DC)
Have an assistant wiggle the AC adapter cable to DC Power Jack.
AC adapter is good? No intermittent reading on multimeter?
Go on.
Remove the Battery. Take a No.2 pencil, and use the eraser to GENTLY, see if you can wiggle the center pin around, of the DC Power Jack in the laptop. (DC_IN)
ANY perceptible movement means a problem with the DC Power Jack.
http://www.amazon.com/POWER-SOCKET-CONNECTOR-SAMSUNG-SERIES/dp/B008AGK43O
Chose link for the 4 views of the DC Power Jack.
Underneath the large Main view, there are 4 smaller views. Click on the one all the way to the right.
This is a view of the Back of the DC Power Jack, and the side that faces in on the laptop.
Note the L-shaped prongs on each side of the jack. These go down into the motherboard, and are soldered to the motherboard.
The 3 vertical lugs you see on the back, are the power, and Ground connections for the jack, and are also connected to the motherboard.
1) The center pin of the jack mounts to the jack's body, like a rivet. It is squished on the back, and this holds it in place.
Very easy to break that mount, and loosen the center pin.
2) The connections on the back are soldered, as previously stated, as are the 'L prongs' on the sides. Solder connections are also known as Solder Joints. If the jack moves with the pencil, and it seems to not just be the center pin, one or more of these solder joints could be cracked. (Broken)
Number 1 above means P-r-o-p-e-r-ly removing the DC Power Jack, and properly soldering a new one in.
Number 2 above just means re-soldering cracked solder joints.
DC Power Jack proves to be good?
Go on.
At this point those who use the moniker 'Technician', but in reality aren't a tech, will want to replace the motherboard.
In reality the Power MOSFET's should be checked, to see if they are good.
IMHO a $4 to $5 P.MOSFET (Or two of them), is much cheaper than a $200 motherboard.
Of course if there is $125 to $150 in labor, the savings isn't that great.
Buy an ESD wrist strap, connect it's alligator clip to a good ground source, remove the motherboard, buy the DC Power Jack, and take both to the tech. Should be about $50 labor, or less to replace the Power MOSFET/s. (May not be both of them, just one)
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you are working on, or a large metal knickknack (Unpainted), and connect to it ]
No Zinzee I do not know what manufacturer, and manufacturer number, of P.MOSFET's are used on your Samsung.
I DO KNOW;
1) They us J-leads on the bottom.
Examples,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
http://www.siliconfareast.com/soic.htm
They are located near the DC Power Jack on the motherboard, usually. Example using HP dv6000 and dv9000 series laptops,
Using Fairchild FDS6679 Power MOSFET as an example,
http://www.ic2ic.com/search.jsp?sSearchWord=FDS6679
$2.74 US
For additional questions please post in a Comment.
Regards,
joecoolvette
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
1helpful
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
1helpful
3answers
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
