Computers & Internet Logo
Question about Samsung Computers & Internet
Ihave a samsung computer series & 700G7A/700G7C I need to know where I can buy the battery A"C adapter and the power cable.I have also the number NP700G7C-T01CA
Posted by ANITA Laurin on
  • Patrik Parker Jul 18, 2019
    Hi ANITA Laurin, I want to help you with your question, but I need more information from you.
    Please Call Customer Service & Support For Help Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
SOURCE: LM1770A POWER ADAPTER 12V
Ok well the Power adapter is not really that special.. what you need is a Centre Pin POSITIVE 12volt at say 4 amp power supply unit. I would get it from Ebay.. perhaps even being able to get an exact one from Ebay.. Othewise try the Samsung site and purchace direct. Look here for an idea. http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=power+supply+for+LCD&_nd1=See-All-Categories
Posted on Aug 01, 2007
Anonymous
  • 84 Answers
SOURCE: Battery
Yup a bad battery in a Dell will cause this issue
A few systems will let you run with no battry ... IBM for one
unfortune that your dell meeds to at least pass voltage ...
do buy a battery to keep a going
LB
Posted on Oct 01, 2008
Anonymous
  • 59 Answers
SOURCE: The computer will only run from a fully charged battery.
friend
the problem clearly shows the fault is in the motherboard
thanks
Posted on Apr 10, 2009
Anonymous
  • 136 Answers
SOURCE: No adapter
Yes, you must purchase a power cord. Even if it could be powered by USB, you would surely run the risk of damaging your PC!
Posted on Sep 03, 2009
Anonymous
  • 807 Answers
SOURCE: no power on hpdv1000
You could have a broken power socket where the charger plugs in to the laptop. If the battery is flat and the socket is broken or loose then it wont charge and will be completely dead. If the socket is ok then it should power up with just the charger plugged in, even without the battery plugged in. You could also have a broken wire in the plug on the charger, the end that plugs in to the laptop.
Posted on Feb 01, 2012
2helpful
2answers
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Samsung R428 notebook wont switch on
This problem, from your description, is very unlikely to be because of a change in your settings, if nothing happens when you try to turn your computer on.
If no power is being supplied to your computer - no lights come on - then
you might just have the combination of a flat battery and a faulty power adapter. You must test the power adapter (measure the output voltage with a voltmeter) or obtain another one (preferably temporarily/borrow) to see if your computer will turn on with that. If your power adapter has failed it must be replaced. If still in warranty, Samsung or your retailer/dealer should replace it at no cost. (you should not attempt to repair a power adapter)
Otherwise (or even as a first step) I suggest you contact Samsung support by email or Live Chat (details are on this
http://www.samsung.com/in/support/model/NP-R428-DA01IN
webpage.) Please have your computer's model number, serial number, operating system and other details to hand (the numbers
can be often be found on labels on the case of your PC)
18.April.2014
RV510 15.6
Check when you turn it ON if you would see the keyboard lights or the CAPS lights respond. If they do, then the unit is ON but your LCD could be defective. Try using an external screen if that is the case.
In case there is really no power coming in, you will need to try and get a hold of a new/spare power cable/adapter and test with it.
Also, try removing the battery and use the laptop with just the power cable.
See the link below on how to remove the battery. Samsung Series RV510
No power on my samsung rv510
Zinzee, check the AC adapter first. (Charger)
Wiggle the power cord from AC adapter to surge protector.
See if the AC adapter LED power on light, blinks.
Yes? Bad power cord.
No change?
Go on.
The port on your laptop that the AC adapter plugs into, is the DC Power Jack.
Wiggle the cable from DC Power Jack to AC adapter.
Power On LED light up, or blink?
Change? New AC adapter. (Also need to check DC Power Jack center pin, to ensure problem is cable, not DC Power jack)
No Change?
Go on.
Unplug the AC adapter from the surge protector. You will need a multimeter now.
An economical multimeter can be purchased for as little as $5 to $12. Available at a multitude of stores. An auto parts store is but one example. (Not for $5 probably )
The Function Knob is set to DC Voltage. (DCV)
If just a symbol it is a dotted line over a solid line.
The center hole in the plug of the cable that goes to the DC Power Jack, is the Positive connection. This is where the RED probe lead (Positive), of the multimeter goes to.
The outside cylindrical metal shell of the plug is the Negative connection. This is what the BLACK probe lead (Negative), touches against.
You should read very close to 19 Volts (DC)
Have an assistant wiggle the AC adapter cable to DC Power Jack.
AC adapter is good? No intermittent reading on multimeter?
Go on.
Remove the Battery. Take a No.2 pencil, and use the eraser to GENTLY, see if you can wiggle the center pin around, of the DC Power Jack in the laptop. (DC_IN)
ANY perceptible movement means a problem with the DC Power Jack.
http://www.amazon.com/POWER-SOCKET-CONNECTOR-SAMSUNG-SERIES/dp/B008AGK43O
Chose link for the 4 views of the DC Power Jack.
Underneath the large Main view, there are 4 smaller views. Click on the one all the way to the right.
This is a view of the Back of the DC Power Jack, and the side that faces in on the laptop.
Note the L-shaped prongs on each side of the jack. These go down into the motherboard, and are soldered to the motherboard.
The 3 vertical lugs you see on the back, are the power, and Ground connections for the jack, and are also connected to the motherboard.
1) The center pin of the jack mounts to the jack's body, like a rivet. It is squished on the back, and this holds it in place.
Very easy to break that mount, and loosen the center pin.
2) The connections on the back are soldered, as previously stated, as are the 'L prongs' on the sides. Solder connections are also known as Solder Joints. If the jack moves with the pencil, and it seems to not just be the center pin, one or more of these solder joints could be cracked. (Broken)
Number 1 above means P-r-o-p-e-r-ly removing the DC Power Jack, and properly soldering a new one in.
Number 2 above just means re-soldering cracked solder joints.
DC Power Jack proves to be good?
Go on.
At this point those who use the moniker 'Technician', but in reality aren't a tech, will want to replace the motherboard.
In reality the Power MOSFET's should be checked, to see if they are good.
IMHO a $4 to $5 P.MOSFET (Or two of them), is much cheaper than a $200 motherboard.
Of course if there is $125 to $150 in labor, the savings isn't that great.
Buy an ESD wrist strap, connect it's alligator clip to a good ground source, remove the motherboard, buy the DC Power Jack, and take both to the tech. Should be about $50 labor, or less to replace the Power MOSFET/s. (May not be both of them, just one)
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you are working on, or a large metal knickknack (Unpainted), and connect to it ]
No Zinzee I do not know what manufacturer, and manufacturer number, of P.MOSFET's are used on your Samsung.
I DO KNOW;
1) They us J-leads on the bottom.
Examples,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
http://www.siliconfareast.com/soic.htm
They are located near the DC Power Jack on the motherboard, usually. Example using HP dv6000 and dv9000 series laptops,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Using Fairchild FDS6679 Power MOSFET as an example,
http://www.ic2ic.com/search.jsp?sSearchWord=FDS6679
$2.74 US
For additional questions please post in a Comment.
Regards,
joecoolvette
Is satelite 4300 wi fi capable? where can i buy battery of sateilte 4300 series?
If your computer has a USB-slot or a PCMCIA-slot, then it is capable of using a USB-to-wireless adapter stick, or a PCMCIA-to-wireless adapter-card.
Look on eBay -- find the model-number on the current battery, and search on eBay, being sure to search both "body" and "title" of eBay listings, to find "compatible" batteries.
When connecting the samsung lan adapter to my samsung led tv 8000 series a message appears saying that the device is connected and set to cable asking if one wants to change it to wireless or not. But if...
There should be a reset either hard,"button" or soft, Plug in the computer and run any software that came with it, Please let me know how you made out, I have been wanting to run my pc movies into my Sammi at the other side of the house, but most of the products I looked at have spotty service at best, There is a new one at Best Buy , that does live streaming in hdmi if you already have the adapter, for lie 60-70 dollars, I will await your response,
Gymowner
Ac adapter for my GE speaker system
This is an old type of PC speaker system. Can it be powered by batteries. How many batteries needed??
Multiply the number of batteries by 1.5 volts and you
get the voltage rating of your needed adapter. You can also take a look at the back of these GE speakers. Maybe you can find the voltage rating.
You may also consider buying a new set of PC speaker that can be plug direct to your power outlet.
You can buy it at a cost slightly higher than your
needed adapter.
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
I lost my battery charger /usb cord for my samsung L201 digital camera and would like to order another one the numbers listed in manual are ac adapter (sac-47) and USB cable(suc-c3) In the picture it...
For charging your Samsung L201, you need the ac adapter (part number AD44-00131A, style SAC-47) and the 20-pin usb cable (part number AD39-00147A, style SUC-C3) both of which can be ordered at www.partstore.com
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
